Ana içeriğe geç
iPhone 16 Microphone Removal
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. iPhone 16 Microphone Removal, Before you begin: adım 1, 2 resimden 1. iPhone 16 Microphone Removal, Before you begin: adım 1, 2 resimden 2.
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 16 Microphone Removal, Tape over any cracks: adım 2, 2 resimden 1. iPhone 16 Microphone Removal, Tape over any cracks: adım 2, 2 resimden 2.
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Microphone Removal, Remove the pentalobe screws: adım 3, 2 resimden 1. iPhone 16 Microphone Removal, Remove the pentalobe screws: adım 3, 2 resimden 2.
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  4. iPhone 16 Microphone Removal, Mark your opening picks: adım 4, 3 resimden 1. iPhone 16 Microphone Removal, Mark your opening picks: adım 4, 3 resimden 2. iPhone 16 Microphone Removal, Mark your opening picks: adım 4, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  5. iPhone 16 Microphone Removal, Heat the bottom edge: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    iOpener
    $14.99
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • You can also use an iOpener to heat the back glass. Follow these instructions to heat and apply the iOpener properly.
  6. iPhone 16 Microphone Removal, Insert an opening pick: adım 6, 3 resimden 1. iPhone 16 Microphone Removal, Insert an opening pick: adım 6, 3 resimden 2. iPhone 16 Microphone Removal, Insert an opening pick: adım 6, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the back glass.
    • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16 Microphone Removal, Back glass information: adım 7, 1 resimden 1.
    • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • A delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • Multiple spring contacts around the perimeter of the phone.
  8. iPhone 16 Microphone Removal, Heat the right edge: adım 8, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
  9. iPhone 16 Microphone Removal, Separate the bottom right adhesive: adım 9, 3 resimden 1. iPhone 16 Microphone Removal, Separate the bottom right adhesive: adım 9, 3 resimden 2. iPhone 16 Microphone Removal, Separate the bottom right adhesive: adım 9, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
    • Slide your pick around the bottom right corner and to the volume down button to separate the adhesive and release the metal clip.
    • Don't slide past the volume buttons to avoid damaging the wireless charging cable.
    • You'll hear and feel the metal clip release as you pass it.
    • Leave this pick inserted to prevent the adhesive from resealing.
  10. iPhone 16 Microphone Removal, Heat the left edge: adım 10, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
  11. iPhone 16 Microphone Removal, Separate the left adhesive: adım 11, 3 resimden 1. iPhone 16 Microphone Removal, Separate the left adhesive: adım 11, 3 resimden 2. iPhone 16 Microphone Removal, Separate the left adhesive: adım 11, 3 resimden 3.
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
  12. iPhone 16 Microphone Removal, Heat the top edge: adım 12, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the top edge of the back glass until it's hot to the touch.
  13. iPhone 16 Microphone Removal, Separate the top right adhesive: adım 13, 3 resimden 1. iPhone 16 Microphone Removal, Separate the top right adhesive: adım 13, 3 resimden 2. iPhone 16 Microphone Removal, Separate the top right adhesive: adım 13, 3 resimden 3.
    • Slide your second opening pick around the top left corner and along the top edge to separate the adhesive and release the metal clips.
    • Continue sliding your pick around the top right corner until you reach the Action button.
  14. iPhone 16 Microphone Removal, Reposition the back glass: adım 14, 3 resimden 1. iPhone 16 Microphone Removal, Reposition the back glass: adım 14, 3 resimden 2. iPhone 16 Microphone Removal, Reposition the back glass: adım 14, 3 resimden 3.
    • At this point, the back glass should be free from the frame. If the back glass feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • Swing open the back glass to the right of the phone to separate the remaining adhesive.
    • Support the back glass with a clean, sturdy object.
    • Remove the opening picks before continuing.
  15. iPhone 16 Microphone Removal, Remove the middle connector cover screws: adım 15, 2 resimden 1. iPhone 16 Microphone Removal, Remove the middle connector cover screws: adım 15, 2 resimden 2.
    • Use a tri-point Y000 driver to remove the two 1 mm‑long screws securing the middle connector cover.
  16. iPhone 16 Microphone Removal, Remove the middle connector cover: adım 16, 3 resimden 1. iPhone 16 Microphone Removal, Remove the middle connector cover: adım 16, 3 resimden 2. iPhone 16 Microphone Removal, Remove the middle connector cover: adım 16, 3 resimden 3.
    • Insert the point of a spudger in either cutout on the middle connector cover.
    • Slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
    • Remove the cover.
  17. iPhone 16 Microphone Removal, Disconnect the battery: adım 17, 2 resimden 1. iPhone 16 Microphone Removal, Disconnect the battery: adım 17, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  18. iPhone 16 Microphone Removal, Disconnect the wireless charging coil: adım 18, 2 resimden 1. iPhone 16 Microphone Removal, Disconnect the wireless charging coil: adım 18, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
  19. iPhone 16 Microphone Removal, Remove the back glass: adım 19, 1 resimden 1.
    • Lift the back glass off the frame and remove it.
  20. iPhone 16 Microphone Removal, Remove the Taptic Engine bracket screws: adım 20, 2 resimden 1. iPhone 16 Microphone Removal, Remove the Taptic Engine bracket screws: adım 20, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 1.8 mm‑long screws securing the Taptic Engine bracket.
  21. iPhone 16 Microphone Removal, Remove the bracket: adım 21, 2 resimden 1. iPhone 16 Microphone Removal, Remove the bracket: adım 21, 2 resimden 2.
    • Use tweezers, or your fingers, to remove the Taptic Engine bracket.
  22. iPhone 16 Microphone Removal, Disconnect the Taptic Engine: adım 22, 2 resimden 1. iPhone 16 Microphone Removal, Disconnect the Taptic Engine: adım 22, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the Taptic Engine press connector.
  23. iPhone 16 Microphone Removal, Remove the Taptic Engine screws: adım 23, 2 resimden 1. iPhone 16 Microphone Removal, Remove the Taptic Engine screws: adım 23, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two screws securing the Taptic Engine:
    • One 2.2 mm‑long screw
    • One 1.7 mm‑long screw
  24. iPhone 16 Microphone Removal, Remove the Taptic Engine: adım 24, 3 resimden 1. iPhone 16 Microphone Removal, Remove the Taptic Engine: adım 24, 3 resimden 2. iPhone 16 Microphone Removal, Remove the Taptic Engine: adım 24, 3 resimden 3.
    • Use the point of a spudger to lift the Taptic Engine out of the frame.
    • Remove the Taptic Engine.
  25. iPhone 16 Microphone Removal, Remove the loudspeaker screws: adım 25, 2 resimden 1. iPhone 16 Microphone Removal, Remove the loudspeaker screws: adım 25, 2 resimden 2.
    • Remove the five screws securing the loudspeaker:
    • Two 1.5 mm‑long Phillips screws
    • One 2.0 mm‑long Phillips screw
    • One 2.9 mm‑long Phillips screw
    • One 1.2 mm‑long tri‑point Y000 screw
  26. iPhone 16 Microphone Removal, Remove the loudspeaker: adım 26, 3 resimden 1. iPhone 16 Microphone Removal, Remove the loudspeaker: adım 26, 3 resimden 2. iPhone 16 Microphone Removal, Remove the loudspeaker: adım 26, 3 resimden 3.
    • Use the point of a spudger to lift the loudspeaker out of the frame.
    • Remove the loudspeaker.
  27. iPhone 16 Microphone Removal, Disconnect the microphone: adım 27, 2 resimden 1. iPhone 16 Microphone Removal, Disconnect the microphone: adım 27, 2 resimden 2.
    • Use the tip of a spudger to disconnect the microphone press connector.
  28. iPhone 16 Microphone Removal, Remove the microphone screws: adım 28, 2 resimden 1. iPhone 16 Microphone Removal, Remove the microphone screws: adım 28, 2 resimden 2.
    • Remove the four screws securing the microphone:
    • Two 3.3 mm‑long standoff screws
    • One 1.1 mm‑long tri‑point Y000 screw
    • One 1.5 mm‑long Phillips screw
    • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
  29. iPhone 16 Microphone Removal, Remove the microphone: adım 29, 3 resimden 1. iPhone 16 Microphone Removal, Remove the microphone: adım 29, 3 resimden 2. iPhone 16 Microphone Removal, Remove the microphone: adım 29, 3 resimden 3.
    • Use the flat end of a spudger to lift the microphone enough to grip it with your fingers.
  30. iPhone 16 Microphone Removal: adım 30, 2 resimden 1. iPhone 16 Microphone Removal: adım 30, 2 resimden 2.
    • Pull the microphone away from the frame to separate the adhesive.
    • Remove the microphone.
Bitiş Çizgisi
Alex Diaz-Kokaisl
226.829 İtibar
1.106 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
124 Üyeler
24.271 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 25
Son 30 gün: 169
Her zaman: 1,837
