Remove the four screws securing the upper connector cover:
Two 1.4 mm-long Phillips screws
One 3.5 mm-long Phillips screw
One 1.0 mm-long tri-point Y000 screw
Use the point of a spudger to pry up and disconnect the two front camera press connectors, located on the top left corner of the logic board.
Pick up the front camera assembly and remove it from your phone.
Sonuç
