Ana içeriğe geç
iPhone 16 Pro Max Charge Port Removal
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. iPhone 16 Pro Max Charge Port Removal, Remove the charge port: adım 1, 3 resimden 1. iPhone 16 Pro Max Charge Port Removal, Remove the charge port: adım 1, 3 resimden 2. iPhone 16 Pro Max Charge Port Removal, Remove the charge port: adım 1, 3 resimden 3.
    • Use a Phillips screwdriver to remove the two 3.3 mm‑long screws securing the charge port to the frame.
    • These screws are tight and can be difficult to reach. Angle your screwdriver at as shallow of an angle as you can, but be careful not to press against the battery.
  2. iPhone 16 Pro Max Charge Port Removal: adım 2, 3 resimden 1. iPhone 16 Pro Max Charge Port Removal: adım 2, 3 resimden 2. iPhone 16 Pro Max Charge Port Removal: adım 2, 3 resimden 3.
    • The charge port has an adhesive gasket that seals it against the bottom of the frame. It's also tucked behind two prongs, which prevents you from pulling the port away from the frame.
    • Insert the point of a spudger under one side of the charge port.
    • Pry up gently to separate the gasket and lift the port up.
    • Repeat on the other side to fully loosen the port.
  3. iPhone 16 Pro Max Charge Port Removal: adım 3, 3 resimden 1. iPhone 16 Pro Max Charge Port Removal: adım 3, 3 resimden 2. iPhone 16 Pro Max Charge Port Removal: adım 3, 3 resimden 3.
    • Remove the charge port.
    • The two screw posts underneath the charge port have grounding clips on them. If the clips fell off, be sure to place them back onto their posts. The clips should face towards the bottom of the iPhone.
Bitiş Çizgisi
Arthur Shi
281.866 İtibar
585 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.418 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 21
