Giriş
Installation steps for installing a logic board for the iPhone 16 Pro Max.
Neye ihtiyacın var
Hold the logic board so that the front sensor cable is close to its connector.
Align the front sensor cable connector carefully over its logic board socket.
Use the point of a spudger or your finger to press the connector until it clicks into place.
Gently bend all the loose press connectors out of the way so you can lay the logic board in place.
Lay the logic board in its recess.
Make sure the logic board rests in place against its screw posts. The posts will properly align the board to the display connector underneath it.
Align the top edge of the earpiece speaker with the top edge of the frame.
Lay the earpiece speaker into its recess.
