Ana içeriğe geç
iPhone 16 Pro Max Logic Board Removal
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. iPhone 16 Pro Max Logic Board Removal, Remove the earpiece speaker: adım 1, 3 resimden 1. iPhone 16 Pro Max Logic Board Removal, Remove the earpiece speaker: adım 1, 3 resimden 2. iPhone 16 Pro Max Logic Board Removal, Remove the earpiece speaker: adım 1, 3 resimden 3.
    • Use the point of a spudger to pry up and disconnect the earpiece speaker and 5G mmWave antenna press connectors.
  2. iPhone 16 Pro Max Logic Board Removal: adım 2, 2 resimden 1. iPhone 16 Pro Max Logic Board Removal: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the six screws securing the earpiece speaker:
    • One 2.4 mm‑long Phillips screw
    • Three 1.3 mm‑long Phillips screws
    • One 1.6 mm‑long Phillips screw
    • One 3.3 mm‑long standoff screw
    • Standoff screws are best removed using a dedicated standoff driver or driver bit. In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  3. iPhone 16 Pro Max Logic Board Removal: adım 3, 3 resimden 1. iPhone 16 Pro Max Logic Board Removal: adım 3, 3 resimden 2. iPhone 16 Pro Max Logic Board Removal: adım 3, 3 resimden 3.
    • Use tweezers to lift and remove the earpiece speaker.
    • You may feel some resistance near the top edge, where the speaker gasket seals against the frame. Pull the speaker out gently to release the seal.
  4. iPhone 16 Pro Max Logic Board Removal, Disconnect the logic board: adım 4, 2 resimden 1. iPhone 16 Pro Max Logic Board Removal, Disconnect the logic board: adım 4, 2 resimden 2.
    • Use a spudger to pry up and disconnect the seven silver press connectors from the top of the logic board.
  5. iPhone 16 Pro Max Logic Board Removal: adım 5, 2 resimden 1. iPhone 16 Pro Max Logic Board Removal: adım 5, 2 resimden 2.
    • Use a spudger to pry up and disconnect the three black press connectors from the logic board.
  6. iPhone 16 Pro Max Logic Board Removal: adım 6, 2 resimden 1. iPhone 16 Pro Max Logic Board Removal: adım 6, 2 resimden 2.
    • Use a standoff driver to remove the four screws securing the logic board:
    • Two 4.5 mm‑long screws
    • One 3.4 mm‑long screw
    • One 4.2 mm‑long screw
  7. iPhone 16 Pro Max Logic Board Removal, Display connector information: adım 7, 1 resimden 1.
    • This image shows the display connector underneath the logic board. The next two steps show how to disconnect this connector from the bottom of the logic board.
  8. iPhone 16 Pro Max Logic Board Removal, Remove the logic board: adım 8, 3 resimden 1. iPhone 16 Pro Max Logic Board Removal, Remove the logic board: adım 8, 3 resimden 2. iPhone 16 Pro Max Logic Board Removal, Remove the logic board: adım 8, 3 resimden 3.
    • If your iPhone has a physical SIM tray, eject it before you proceed.
    • Make sure all the connectors are disconnected from the top of the logic board.
    • Insert the flat edge of an opening pick between the battery and the left edge of the logic board. Hold the pick in place with your fingers.
    • Insert the flat end of a spudger underneath the right edge of the logic board.
    • Gently pry with the spudger to lift the logic board and disconnect the display connector.
    • Don't remove the logic board yet. There's still a cable connected to the bottom side.
  9. iPhone 16 Pro Max Logic Board Removal: adım 9, 2 resimden 1. iPhone 16 Pro Max Logic Board Removal: adım 9, 2 resimden 2.
    • Flip the logic board over, being careful not to strain the connected cable.
    • Use the point of a spudger to pry up and disconnect the front sensor connector from the bottom side of the logic board.
  10. iPhone 16 Pro Max Logic Board Removal: adım 10, 1 resimden 1.
    • Remove the logic board.
Bitiş Çizgisi
Arthur Shi
281.866 İtibar
585 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.418 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 23
