Ana içeriğe geç
iPhone 1st Generation Camera Replacement
Neye ihtiyacın var
    1. iPhone 1st Generation Camera Replacement, SIM Card: adım 1, 1 resimden 1.
      • Insert a SIM card eject tool or paper clip into the hole next to the headphone jack.
      • Press down on the paper clip until the SIM card tray pops out.
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 1st Generation Camera Replacement: adım 2, 1 resimden 1.
      • Grasp the SIM card tray and slide it out of the iPhone.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 1st Generation Camera Replacement, Antenna Cover: adım 3, 1 resimden 1.
      • This image shows the two tabs and two catches located on the underside of the antenna cover. The two tabs at the top of the image must be pushed towards the black cover to release them.
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 1st Generation Camera Replacement: adım 4, 1 resimden 1.
      • Be sure to slide the metal spudger between the dock connector and the antenna cover, and not into the dock connector itself.
      • Insert a metal spudger into the slot between the dock connector and the antenna cover. Gently pry up near the two tabs to create a small gap between the antenna cover and the silver front bezel.
      FixBot'a Sor
      Yorum Ekle
    3. iPhone 1st Generation Camera Replacement: adım 5, 1 resimden 1.
      • Insert an iPod opening tool in the gap between the antenna cover and the front bezel. The wedge of the tool should be pointing towards the antenna cover. Slide the tool around the corner and up until you reach the metal backing.
      • Repeat the same procedure on the other side of the dock connector.
      FixBot'a Sor
      Yorum Ekle
    4. iPhone 1st Generation Camera Replacement: adım 6, 1 resimden 1.
      • Grasp the antenna cover on either side and slide it up and away from the iPhone. This requires some force. If it does not come free, ensure that the antenna cover is lifted up enough to free the catches.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 1st Generation Camera Replacement, Case: adım 7, 1 resimden 1.
      • Remove the three Phillips #00 screws securing the rear panel to the iPhone.
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 1st Generation Camera Replacement: adım 8, 1 resimden 1.
      • Getting the iPhone open is a challenging feat, so don't get discouraged. Take a deep breath and make sure you have plenty of time to get the job done.
      • The small square hole is the location to insert the dental pick in the next step.
      FixBot'a Sor
      Yorum Ekle
    3. iPhone 1st Generation Camera Replacement: adım 9, 1 resimden 1.
      • Start removing the rear panel on the side with the buttons.
      • Slide the dental pick completely into the square hole. You may need to wiggle the tool and apply a good amount of force to get it to go all the way.
      FixBot'a Sor
      Yorum Ekle
    4. iPhone 1st Generation Camera Replacement: adım 10, 1 resimden 1.
      • Pry up the rear panel by pulling the dental pick counterclockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
      FixBot'a Sor
      Yorum Ekle
    5. iPhone 1st Generation Camera Replacement: adım 11, 1 resimden 1.
      • Use a spudger to free the rear panel from the iPhone along the corner and top.
      FixBot'a Sor
      Yorum Ekle
    6. iPhone 1st Generation Camera Replacement: adım 12, 1 resimden 1.
      • Repeat the same procedure on the other side of the iPhone. Slide the dental pick completely into the square hole. You may need to wiggle the tool and apply a good amount of force to get it to go all the way.
      FixBot'a Sor
      Yorum Ekle
    7. iPhone 1st Generation Camera Replacement: adım 13, 1 resimden 1.
      • Pry up the rear panel by pulling the dental pick clockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
      • The rear panel is still attached to the iPhone by the headphone jack cable, so don't entirely remove the rear panel from the iPhone just yet.
      FixBot'a Sor
      Yorum Ekle
    8. iPhone 1st Generation Camera Replacement: adım 14, 1 resimden 1.
      • Make sure the phone is off before disconnecting the headphone jack cable.
      • Use a spudger to disconnect the headphone jack cable from the logic board.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 1st Generation Camera Replacement, Camera: adım 15, 1 resimden 1.
      • Use a spudger to disconnect the camera connector.
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 1st Generation Camera Replacement: adım 16, 1 resimden 1.
      • Lift the camera out of the iPhone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
29 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 21
Son 30 gün: 75
Her zaman: 71,223
