Ana içeriğe geç
iPhone 3G Display Assembly Replacement
Neye ihtiyacın var
Videoya Genel Bakış
    1. iPhone 3G Display Assembly Replacement, Broken Glass: adım 1, 3 resimden 1. iPhone 3G Display Assembly Replacement, Broken Glass: adım 1, 3 resimden 2. iPhone 3G Display Assembly Replacement, Broken Glass: adım 1, 3 resimden 3.
      • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 3G Display Assembly Replacement, Display Assembly: adım 2, 1 resimden 1.
      • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 3G Display Assembly Replacement: adım 3, 1 resimden 1.
      • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
      • Be very careful when opening the iPhone so that the cables under the display are not severed.
      • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
      • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
      • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape may be used.
      FixBot'a Sor
      Yorum Ekle
    3. iPhone 3G Display Assembly Replacement: adım 4, 1 resimden 1.
      • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
      • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
      FixBot'a Sor
      Yorum Ekle
    4. iPhone 3G Display Assembly Replacement: adım 5, 1 resimden 1.
      • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
      FixBot'a Sor
      Yorum Ekle
    5. iPhone 3G Display Assembly Replacement: adım 6, 1 resimden 1.
      • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
      • Use a spudger to disconnect the black ribbon cable labeled "2."
      FixBot'a Sor
      Yorum Ekle
    6. iPhone 3G Display Assembly Replacement: adım 7, 1 resimden 1.
      • Use a spudger to flip up the black plastic tab holding the remaining ribbon cable in place. The black will rotate up 90 degrees, releasing the ribbon cable.
      • The tab is very fragile, so be careful when flipping it up to unlock the cable and down to lock the cable.
      • The plastic tab may be white (instead of black) on some iPhone models.
      • Slide the ribbon cable out of its connector, and remove the display assembly from the iPhone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
229 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
i went through the whole process, but my home button does not work anymore. it was fine when I started - its it possible, that one ribbon is not fully attached ore is there any other solution? Thanks for any advice!
Jakob
JakobBartke - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 74
Her zaman: 305,387
