Ana içeriğe geç
iPhone 3GS Dock Connector Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. iPhone 3GS Dock Connector Replacement, Broken Glass: adım 1, 3 resimden 1. iPhone 3GS Dock Connector Replacement, Broken Glass: adım 1, 3 resimden 2. iPhone 3GS Dock Connector Replacement, Broken Glass: adım 1, 3 resimden 3.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    FixBot'a Sor
    Yorum Ekle
  2. iPhone 3GS Dock Connector Replacement, Dock Connector: adım 2, 1 resimden 1.
    • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
    FixBot'a Sor
    Yorum Ekle
  3. iPhone 3GS Dock Connector Replacement: adım 3, 1 resimden 1.
    • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
    • Be very careful when opening the iPhone so that the cables under the display are not severed.
    • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
    • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
    • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape maybe used.
    FixBot'a Sor
    Yorum Ekle
  4. iPhone 3GS Dock Connector Replacement: adım 4, 1 resimden 1.
    • The display assembly is still connected to the iPhone by three cables, so don't try to remove it entirely just yet.
    • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
    • Be careful. Sometimes cable 4 can stick to the back of the display assembly and can be pulled off and/or torn as you remove the display assembly.
    FixBot'a Sor
    Yorum Ekle
  5. iPhone 3GS Dock Connector Replacement: adım 5, 1 resimden 1.
    • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
    • Start from the ribbon and work your way towards the outside edge of the case.
    FixBot'a Sor
    Yorum Ekle
  6. iPhone 3GS Dock Connector Replacement: adım 6, 1 resimden 1.
    • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
    • Use a spudger to disconnect the black ribbon cable labeled "2."
    FixBot'a Sor
    Yorum Ekle
  7. iPhone 3GS Dock Connector Replacement: adım 7, 1 resimden 1.
    • Use a spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
    • Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
    FixBot'a Sor
    Yorum Ekle
  8. iPhone 3GS Dock Connector Replacement: adım 8, 1 resimden 1.
    • Insert your SIM eject tool or a paper clip into the hole next to the headphone jack.
    • Press down on the tool until the SIM card tray pops out.
    • Grasp the SIM card tray and slide it out of the iPhone.
    FixBot'a Sor
    Yorum Ekle
  9. iPhone 3GS Dock Connector Replacement: adım 9, 1 resimden 1.
    • Use a spudger to disconnect the ribbon cable labeled "4."
    FixBot'a Sor
    Yorum Ekle
  10. iPhone 3GS Dock Connector Replacement: adım 10, 1 resimden 1.
    • Use a spudger to disconnect the ribbon cable labeled "5."
    FixBot'a Sor
    Yorum Ekle
  11. iPhone 3GS Dock Connector Replacement: adım 11, 2 resimden 1. iPhone 3GS Dock Connector Replacement: adım 11, 2 resimden 2.
    • Use a spudger to disconnect the ribbon cable labeled "6."
    • If you have an iPhone 3GS, refer to picture 2 and use a spudger to disconnect the ribbon cable labeled "7."
    FixBot'a Sor
    Yorum Ekle
  12. iPhone 3GS Dock Connector Replacement: adım 12, 1 resimden 1.
    • Carefully peel up the small sticker labeled "Do not remove."
    FixBot'a Sor
    Yorum Ekle
  13. iPhone 3GS Dock Connector Replacement: adım 13, 1 resimden 1.
    • Remove the following 8 screws:
    • Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel.
    • Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
    • One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
    FixBot'a Sor
    Yorum Ekle
  14. iPhone 3GS Dock Connector Replacement: adım 14, 1 resimden 1.
    • Use a spudger to gently remove the camera retaining clip, (formerly secured by the removed screw) and gently pry the camera up and out of its housing in the rear panel. The camera cannot be removed entirely yet because it's connected to the bottom of the logic board.
    FixBot'a Sor
    Yorum Ekle
  15. iPhone 3GS Dock Connector Replacement: adım 15, 1 resimden 1.
    • Use a spudger to gently pry up the end of the logic board closest to the dock connector.
    • There is a small golden grounding tab on the logic board adjacent to the 'Do not remove' sticker. Be very careful this does not snag on the side of the case when prying up the logic board; it breaks easily! If you have signal problems after removing the logic board, check this ground tab.
    • If the board won't lift up, double check to make sure all 8 screws securing the logic board have been removed.
    FixBot'a Sor
    Yorum Ekle
  16. iPhone 3GS Dock Connector Replacement: adım 16, 1 resimden 1.
    • Slide the logic board towards the dock connector and out of the iPhone.
    FixBot'a Sor
    Yorum Ekle
  17. iPhone 3GS Dock Connector Replacement: adım 17, 1 resimden 1.
    • Remove the following 3 screws:
    • Two 1.5 mm Phillips #00 screws, one on either side of the dock connector.
    • One 2.4 mm Phillips #00 screw near the ribbon cable labeled "4."
    FixBot'a Sor
    Yorum Ekle
  18. iPhone 3GS Dock Connector Replacement: adım 18, 1 resimden 1.
    • Lift the dock connector assembly up and out of the iPhone.
    • When inserting the new assembly, ensure the screw holes of the assembly rest ABOVE the bezel's holes.
    FixBot'a Sor
    Yorum Ekle
Sonuç
298 farklı kişi bu kılavuzu tamamladı.
11Kılavuz Yorumları
When closing the phone (Step 3 - but when going backwards) it is important to be aware of the the contact for the HOME button. They are two little gold contacts that have to hit against two solder points on the dock assembly. I managed to bend them a bit out of alignment, so when I closed up the iPhone the home button was no longer working. Easily fixed, but worth noting.
Peter - Yanıt Paylaş
When replacing the connector you will have to desolder 4 small solder points, 2 per ribbon cable. They are easily desoldered by gently pressing the soldering iron tip to the top of the cable and gently peeling it away.
They can they be resoldered onto the new connector.
The solder points can be seen in step 16 just above the two 1.5mm screws.
scottreschke - Yanıt Paylaş
Hi, I followed the instructions and all went well, except for now I have very bad reception problems. I keep getting 'No Service' and cant really make calls. :-(
Could I have damaged the antenna somehow? I have found the antenna stickers online for sale but havent found any instructions as to how to install it...
Any help would be much appreciated.
Thanks
Fu82 - Yanıt Paylaş
the sample phone looks like a 3G nto a 3Gs. I have an extra wire connection on top of the dock connector in my 3Gs.
mlstrykher - Yanıt Paylaş
If you're purchasing a Phillips screwdriver for this I'd highly recommend getting one that has a magnetic tip. I bought the cheaper screwdriver from iFixit but wish I would've sprung for the "professional" version (which I assume does have a magnetic tip). It can be done without it (I did it) but it took much longer than it would have otherwise.
wpaul - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 58
Her zaman: 229,036
