Ana içeriğe geç
iPhone 4 后盖更换
Neye ihtiyacın var
  1. iPhone 4 后盖更换, 后盖: adım 1, 2 resimden 1. iPhone 4 后盖更换, 后盖: adım 1, 2 resimden 2.
    • 在开始之前,将您的iPhone电池放电低于25%。 已充电的锂离子电池如遇意外穿刺,可能会起火和/或爆炸。
    • 在开始拆卸前关闭iPhone的电源。
    • 您的iPhone 4后盖可能有两个#000十字螺丝或苹果的5点“Pentalobe”螺丝(第二张图)。 检查你有哪些螺丝,并确保你也有正确的螺丝刀,以拆下它们。
    • 拆卸两个3.6毫米或000 pentalobe菲利普斯#螺丝旁边的基座连接器。
    • 拆卸Pentalobe螺丝时,确保驱动器安装牢固,非常容易剥离。
  2. iPhone 4 后盖更换: adım 2, 2 resimden 1. iPhone 4 后盖更换: adım 2, 2 resimden 2.
    • 把后盖向上推到边框的边缘。
    • 后盖大约移动 2 mm。
  3. iPhone 4 后盖更换: adım 3, 1 resimden 1.
    • 用手指将后盖取下。还有一种方法,用吸盘取下。
    • 注意不要把后盖的塑料卡扣损坏。
    • 如果你要安装新的后盖,需要将摄像头的塑料保护贴纸和较大黑色区域的贴纸撕下。
Sonuç
请倒序重组你的设备。
806 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
en zh
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
9 Yorum
sorry, I do this without entering the silent mode.
What problems might have
Michele - Yanıt
The replacement part for the iPhone 4 rear panel has two thin, clear overlays on the inside surface--a larger one that runs the full length, and a small one that only covers the lens. These should be removed prior to installation. Also, the first rear panel replacement I got from iFixit was not an exact fit and would not easily "click" into place. They replaced it for free and the second one clicked right in.
rudisill49 - Yanıt
In the blog post about this item there is mention of removing the shielding, maybe this tutorial could go into detail about removing the shielding, with the appropriate, this will kill your iPhone warnings
Chris - Yanıt
On step 3 when replacing the back panel with a new one, they aren't kidding about removing ALL the protective slips. There's THREE of them.
1), the obvious back slip that protects the new back.
2). the one inside the back protecting the side with the camera lens
3). the little square one OVER the lens itself.
First time I tried to reinstall my back, that tiny little square over the lens prohibited my ability to actually get the back on completely. My husband jammed it for me, but the screws still wouldn't take. It's amazing that these things are so precise that the tiny little film on the lens would make it that much tighter.
Anyways, hope that helps somebody. :)
rachelfinder - Yanıt
Easiest repair I've ever done. Thanks y'all!
patrickbeeson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 28
Son 30 gün: 163
Her zaman: 1,000,688
