Giriş
Entering DFU Mode (Official Instructions)
1. Plug your device into your computer.
2. Turn off the device.
3. Hold the Power button for 3 seconds.
4. Hold the Home button without releasing the Power button for 10 seconds.
5. Release the Power Button but keep holding the Home button.
6. Keep holding the Home button until you are alerted by iTunes saying that it has detected a device in Recovery Mode
Make sure the device screen is blank and no logos are present. Same operation you can use for all other models of iPhone.
Videoya Genel Bakış
Open iTunes. The iPhone must be connected to the PC and powered OFF.
Entering DFU mode.
Instruction you can read at the description.
iTunes has detected an iPhone in recovery mode.
Your iPhone is factory restored now.
Did you do it successfully?
itune ne detecte meme l'iphone
j’ai bien commencé mais lors du téléchargement le phone s’est allumé de lui même. pourquoi ???
“Password recovery” is where?
I cannot reach the 4th step ; my iPhone 4s return to recovery mode and can’t restore why ?
and when I try to flash it or exit the recovery mode from “ 3utools “ it fails and doesn’t work.
avec cette technique j’aurais encore besoin d’entrer le dernier compte iCloud utilisé sur le téléphone ou bien
This guide does not need reassembly.
455 farklı kişi bu kılavuzu tamamladı.
99 Yorum
My iphone 4 is locked and i dont know the apple id so by doing this i can unlock it or not please help
If your phone is carrier locked or iCloud locked - no.
ZFix -
contact me to unlock iphone 4 icloud lock
@Himanshu Rattan
how can i contact?
When i connect my iPhone in pc it doesn't shows in pc.
Comment via:- http://www.Techmash.in
how if there's icloud account logged ? it will be icloud locked?
Officially the iCloud lock can be removed only fro the owner.
ZFix -
I got problem with my iphone 4s icloud I'd I don't know how to remove plzz help me
I don't know how to solve your problem when your iPhone get into DFU mode, but I know how to recover iTunes backup password if you forgot iTunes backup password, I personally suggest you try iSeePassword iTunes backup password recovery.
I can hear voice of my iphone 4s on call and ring tone properly but when it comes to play music or listening whatsapp voice message i cannot hear voice without headfone.... Can somebody help
same problem i am facing can anyone help us
I have some problem of my iphone 4 (wifi disable)
how to resolve...
can anybody help me???
Sounds like you need to do this
My phone is stuck in recovery mode and it will not come out it. Could you help and tell me what to do to try and to get it out recovery mode. Thanks
no way i will be getting this
KENIYAH -
I'm doing the update and restore on my iPhone5s but when it gets to restoring firmware it stops and says an error occur. I've tried over and over again still the same. Now when I turn the phone on all it shows is the iTunes logo and usb sign under it. Please what do I do?
sicrt cold u can use to open ur phone
Hello,
I bought a second hand iphone6 plus from a friend. And I went to go use it and I can't because it is still conceded to the original owners apple Id account. And I have NOOO WAAYYYY nor do I know the original owner.
What do I do?
Please help
Thank you
go back to your thieving friend!
Itunes say "off find my iphone" but my iphone is in disable mode cause i forgot password
My Iphone 6s+ is disable nd didnt get backup nd didnt known apple id nd password say me in detail plz sir say me
ya email / whats app me
patelharshp2015@gmail.com
+918866181732
My Dad Bought An Iphone 5s, And Now He Forgets The Password And Everything That Linked With The APPLE ID. How to Remove That Account outta my Iphone?
Iif you flash an iphone 4s trying to unlock it and after couple of hours the iphone refuses to turn on again what can be done to it,this iphone is a gift and it has been locked down to only emergency calls.
i am at step 4 and i am receiving this "Your iphone could not be activated because the activation server cannot be reached.
Try connecting your iphone to iTunes to activate it, or try again in a couple of minutes. If this problem persists, contact Apple Support at apple.com/support.
Here i am please help
what is activation server?
forgot the password of the apple id,so by flashing it can it help me to create a new one?
no you cant if you turned on Find My iPhone. if you follow this guide while turning Find My iPhone on, when you make activation then it will require you type the apple id existed before. now this guide cant remove password.
ycwei982 -
Thanks for this guide. Nice job (y)
where firmware any i phone link....plz....
Try this site, if you haven't found one yet!
hello, my iphnone 5s fell in water and now its try to turn on but keep rebooting. i have tried to put it in DFU mode but its not responding. what can i do please help me
Have you ever tried any guide to recover your phone from getting water? If not, go for it. I suggest you using recover mode at first, as it has response on the screen. Turn on your phone, and when it shows Apple logo, release power button then long press the home button. If it works it will show "Connect to iTunse".
ycwei982 -
my iphone is not icloud locked.. is this going to remove my password ??
frimwar iphone : http://bluenik.com/1Esr
l’iPhone et l’iPod Touch, l’iPad, l’iPad mini, l’Apple TV ainsi que toutes les version d’iTunes :http://bluenik.com/1Esz
not working to me... i have iphone 4 32gb... http://indoxxi.info nonton film movie online
nice sir ji
get here mor e https://hackmobiletrick.blogspot.in/
My iphone4 is locked with Apple ID .with this process can I flash the iPhone please help
Hello,
I'm sorry but if your device is locked with an Apple ID, this guide will not help you. Only you can do is to login with the Apple-ID which is linked to your iPhone.
Zaim -
My iPhone 5c is full/ZERO memory storage. I compute all the data/apps that I've downloaded and 1GB+ free space must be remained. I do delete some apps, vedios, pics and etc. but it still full memory storage.
This DFU mode can fixed it?
Thank you.
Hy,
if you boot your iPhone in DFU mode and proceed a restore, all data will be removed and it will look like a new iPhone.
Zaim -
my iphone is locked and i cant get my apple id
when its extracts the file in itunes it restarts again and again
my iphone 6, which i have used for a year plus has been disabled, i forgot my pass-code just after changing, i have tried restoring buts there comes an error...'disc full, delete and empty the recycle bin . retry again"
how can i do it yet its already locked? help please.
You have to put it in the DFU Mode and not in to the restore mode
Zaim -
My iPhone in locked with icloud but I forget apple id and password and I also loss my all apple document . So how can start my iPhone plz advised me sir
When you turn you iPhone on, there is a hidden email with big black dots in it, you have to reset your password for this email, otherwise you can throm you iPhone away
Zaim -
Do i need to download any app on my pc?
Yes, you have to download iTunes. You can download it from itunes.com
Zaim -
i dont remember my icloud account ,so my problem is i stuck in icloud account ,i reset my phone then i cant log in .they said incorrect password
You can go here: https://iforgot.apple.com/password/verif... and reset you password
Zaim -
Will This unlock me from straight talk?
my iphone 5 has been labeled “connect to itunes” but when i connect, it doesn’t show on my pc….. can some one help please
I really hate flashing apple devices….
give me sicrit cold to poen i phone
yar thori urdu v type kiya karo kisi aur ko be samj a jay
My iphone 5s is icloud locked. Bought it from second hand. Please help
I have Iphone 4 and is Icloud lockes. How can I resolve this? Mail me at daphethy@outlook.com
Pls how can i unlock iphone 6 that has icloud lock
This is very nice guide how to unlocked your iPhone. But I use one of this to unlock my iPhone 8 on other SIM card. I thing that this tool can’t unlock any iCloud Locked iPhone.
hi My iPhone 6 was 32 Gb and after the guy repaired than its now 16 Gb … loll and the guy is asking me to flash restore the phone I did that but its still the same….
what can be the reasons???
I am going to him again today
My sister bought iPhone 5 locked by iCloud and password now she can't use the iPhone and a person who sold the iPhone disappeared. Help please.
pls pls help me remove icloud from my iphone 5
Check Here i am also have some solution to flash Iphones- How to Flash iPhones without iTunes
Can I recover my lost password without loosing data? Technikola
Please my dad forgot his apple ID ND he already flashed the iPhone and he can't remember his email too..please what do I do??
Bagaimana cara,y buka iphone 5s
I got error massage after all procedure
İphone 7 plus we have it droped. I try do restore it. İt gives me the error 1. İtis not good error ı know that. What we are going to do first .?
What is the error that you are seeing on your iPhone/iTunes? That would better help us to determine what your next steps are to be taken!
have an iphone 4s whic h i collected kindly unlock for me
hi Himanshu, I have a iPhone 5S locked icloud, do you know how to unlock it ? my email : georges001@cegetel.net
it doesn’t work with icloud removal
where do i get firmware of iphone 6 plus
slt j’ai un iPhone 6 qui redémarre en boucle sans cesse au niveau de la pomme comment y faire? merci.
I need help on resetting my iphone 4
My iPhone 5s is on ICloud pls I can I remove it
How can I remove my iPhone 5s from iCloud. I no my username but I can’t remember my password
How can I contact? My iphone 4 is locked and i don’t know the apple id
Salut!! Mais es-ce-que céla permettra de supprimer le compte iCloud sur l’iphone?
