Giriş
Use this guide to replace a blown-out earpiece speaker.
Power off your iPhone before beginning disassembly.
Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
Use the clear plastic pull tab to gently lift the battery out of the iPhone.
If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
Before reconnecting the battery connector, be sure the contact clip (shown in red) is properly positioned next to the battery connector.
Use a SIM card eject tool or a paperclip to eject the SIM card and its holder.
Remove the SIM card and its holder.
Use an iPod opening tool to slightly lift the top edge of the Wi-Fi antenna away from the logic board.
Use the tip of a spudger to pull the Wi-Fi retaining clips away from the inner frame.
Remove the Wi-Fi antenna from the iPhone. Make sure you don't lose the metal clips on the top of the cover where the 4.8mm screw attaches or the 4.8mm screw. That's the primary reason for abnormal Wi-Fi performance after the reassembly.
Use the edge of a plastic opening tool to gently pry the following connectors up and out of their sockets on the logic board:
Digitizer cable (pry from bottom)
LCD cable (pry from bottom)
Headphone jack/volume button cable (pry from top)
Top Microphone/sleep button cable (pry from top)
Front camera cable (pry from top)
Remove the 4.8 mm standoff screw near the headphone jack.
Without this part, the motherboard could damage the ribbon cables around it.
Use the edge of a plastic opening tool to pry the earpiece speaker off the adhesive securing it to the front panel.
Remove the earpiece speaker.
261 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
7 Comments
Excellent guide. The earpiece speaker grill was clogged after I accidentally spilled coffee on the phone and was unable to hear my calls, oops. Following this guide I was able to clean out the screen with alcohol and compressed air. I couldn't have done it without this great guide. Thanks so much to all the authors and editors!!!
amazing guide! thanks for share it with us!
I did it!!! carefull with the ribbon on the edge of the board... the Ear Piece from ifixit is too expansive as the prices of parts. The quality is not too good as the original too i think.
