Ana içeriğe geç
iPhone 4 Verizon Dock Connector Cable Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. iPhone 4 Verizon Dock Connector Cable Replacement, Dock Connector Cable: adım 1, 2 resimden 1. iPhone 4 Verizon Dock Connector Cable Replacement, Dock Connector Cable: adım 1, 2 resimden 2.
    • Remove the two 1.8 mm Phillips screws securing the dock connector cable to the logic board.
    • Remove the thin metal dock connector cable cover.
  2. iPhone 4 Verizon Dock Connector Cable Replacement: adım 2, 1 resimden 1.
    • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
  3. iPhone 4 Verizon Dock Connector Cable Replacement: adım 3, 1 resimden 1.
    • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
  4. iPhone 4 Verizon Dock Connector Cable Replacement: adım 4, 2 resimden 1. iPhone 4 Verizon Dock Connector Cable Replacement: adım 4, 2 resimden 2.
    • Remove the 1.6 mm Phillips screw securing the pressure contact to the logic board near the vibrator.
    • Remove the pressure contact.
  5. iPhone 4 Verizon Dock Connector Cable Replacement: adım 5, 2 resimden 1. iPhone 4 Verizon Dock Connector Cable Replacement: adım 5, 2 resimden 2.
    • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
    • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
    • When reconnecting the antenna wire be VERY certain that the round connector at the end of the wire is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connector.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 20
Her zaman: 1,172
