Giriş
Use this guide to replace the headphone jack cable which also contains the upper microphone and electronic portions of the volume buttons and silent switch.
Power off your iPhone before beginning disassembly.
Your phone's rear cover may have two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws. Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
Remove the single 1.5 mm Phillips screw securing the battery connector to the logic board (if present).
Pull up on the exposed clear plastic tab to peel the battery off the adhesive securing it to the iPhone.
If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
Remove the battery.
Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
Remove the two 1.8 mm Phillips screws securing the dock connector cable to the logic board.
Remove the thin metal dock connector cable cover.
Remove the following five screws:
Three 1.3 mm Phillips screws
One 1.5 mm Phillips screw
One 2.4 mm Phillips screw
Disconnect the five cables near the top of the logic board in the following order:
Headphone jack/volume button cable
Power button cable
Front facing camera cable
Digitizer cable
Display data cable
To disconnect the cables, use the edge of a plastic opening tool to gently lift their connectors up and out of the sockets on the logic board.
Remove the 2.5 mm Phillips #000 screw securing the logic board near the power button.
Remove the 4.8 mm standoff screw near the headphone jack.
Use the edge of a plastic opening tool to carefully pry the metal front facing camera retainer away from the case of your iPhone.
Remove the front facing camera retainer.
Use the edge of a plastic opening tool to peel the upper antenna off the headphone jack.
Remove the four 1.6 mm Phillips screws securing the volume button and silent switch brackets to the outer case.
28 farklı kişi bu kılavuzu tamamladı.
