Ana içeriğe geç
iPhone 4 Volume Button Replacement
Neye ihtiyacın var
  1. iPhone 4 Volume Button Replacement, Rear Panel: adım 1, 2 resimden 1. iPhone 4 Volume Button Replacement, Rear Panel: adım 1, 2 resimden 2.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
    • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
    • Be sure the driver is well seated when removing Pentalobe screws, they are very easy to strip.
    FixBot'a Sor
    Yorum Ekle
  2. iPhone 4 Volume Button Replacement: adım 2, 2 resimden 1. iPhone 4 Volume Button Replacement: adım 2, 2 resimden 2.
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
    FixBot'a Sor
    Yorum Ekle
  3. iPhone 4 Volume Button Replacement: adım 3, 1 resimden 1.
    • Pinch the rear panel with your fingers and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
    • Be careful not to damage the plastic clips attached to the rear panel.
    • If you are installing a new rear panel, be sure to remove the plastic protective sticker from the inside of the camera lens and the sticker from the large black area near the lens.
    FixBot'a Sor
    Yorum Ekle
  4. iPhone 4 Volume Button Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
    • Some devices may have two screws, one of which holds down the contact pad which is located above the screw indicated in red in the photo.
    FixBot'a Sor
    Yorum Ekle
  5. iPhone 4 Volume Button Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Pry from the top and bottom of the connector bracket—there isn't as much of an overhang on the sides, and you may damage the connector.
    • Be very careful to only pry up on the battery connector and not the socket on the logic board. If you pry up on the logic board socket, you may break it entirely.
    • Remove the metal clip covering the antenna connector.
    FixBot'a Sor
    Yorum Ekle
  6. iPhone 4 Volume Button Replacement: adım 6, 3 resimden 1. iPhone 4 Volume Button Replacement: adım 6, 3 resimden 2. iPhone 4 Volume Button Replacement: adım 6, 3 resimden 3.
    • Use the clear plastic pull tab to gently lift the battery out of the iPhone.
    • If the tab breaks before the battery is freed, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery. Wait about one minute for the alcohol solution to weaken the adhesive. Carefully slide a spudger under the battery tab to release the adhesive.
    • Prying in other places may cause damage. Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
    • Before reconnecting the battery connector, be sure the contact clip (shown in red) is properly positioned next to the battery connector.
    • Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
    FixBot'a Sor
    Yorum Ekle
  7. iPhone 4 Volume Button Replacement, Volume Button: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to remove the small strip of tape covering the back of the volume buttons.
    • Be sure to peel the tape starting from nearest the top of the phone.
    FixBot'a Sor
    Yorum Ekle
  8. iPhone 4 Volume Button Replacement: adım 8, 1 resimden 1.
    • Remove the three Phillips screws securing the volume button bracket to the outer case.
    FixBot'a Sor
    Yorum Ekle
  9. iPhone 4 Volume Button Replacement: adım 9, 1 resimden 1.
    • Use a pair of tweezers to gently pull the volume button bracket slightly away from the outer case.
    FixBot'a Sor
    Yorum Ekle
  10. iPhone 4 Volume Button Replacement: adım 10, 1 resimden 1.
    • Remove the volume button from the iPhone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
87 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
The attached PDF document for the screw is very well thought out. Thank you for your hard work,
3MFIX TECHNOLOGY - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 75
Her zaman: 125,140
