Giriş
This guide consists of instructions on how to replace the battery in an iPhone 4S.
Neye ihtiyacın var
Remove the two bottom Pentalobe screws next to the 30-Pin connector.
Push the back panel towards the top of the iPhone. Doing this should allow the back panel to slide off safely.
Remove these two screws that are securing the battery connector to the Logic Board.
Locate and pull the plastic tab to pull out the battery. Make sure to pry up on the outside of the battery on all sides.
62 farklı kişi bu kılavuzu tamamladı.
