Ana içeriğe geç
iPhone 4S Battery Replacement
Neye ihtiyacın var
  1. iPhone 4S Battery Replacement, Pentalobe Screws: adım 1, 1 resimden 1.
    • Remove the two bottom Pentalobe screws next to the 30-Pin connector.
    • It is recommended that you use a small 5-Point screwdriver for this process.
    • Remember to make sure your iPhone is fully turned off before commencing this process, to prevent serious injury to the phone.
    Any Chinese Here?
    I need a teacher_(:з」∠)_
    JackWang47 - Yanıt
    啥意思?我就是Chinese,有啥问题可以加我WeChat
    Ray Hou -
    This iPhone has seen some stuff
    Duck - Yanıt
    Which way do you turn the screw to get it out?
    Duck B - Yanıt
    Counterclockwise, of course.
    guardian10 -
  2. iPhone 4S Battery Replacement, Back Panel Removal: adım 2, 2 resimden 1. iPhone 4S Battery Replacement, Back Panel Removal: adım 2, 2 resimden 2.
    • Push the back panel towards the top of the iPhone. Doing this should allow the back panel to slide off safely.
    • Do not apply too much pressure to the back. Especially if your phone has a cracked back panel.
    • Do not rush it! Time is key.
  3. iPhone 4S Battery Replacement, Battery Screws: adım 3, 1 resimden 1.
    • Remove these two screws that are securing the battery connector to the Logic Board.
    • Beware of unscrewing the battery connector, as your screwdriver does have the possibility to slip and pierce the battery.
    • For the bottom screws, it is recommended that you use a 1.5 mm screw bit, and a 1.7 mm for the top screw.
  4. iPhone 4S Battery Replacement, Battery Strip: adım 4, 1 resimden 1.
    • Locate and pull the plastic tab to pull out the battery. Make sure to pry up on the outside of the battery on all sides.
    • Do not pull on the plastic tab too hard, as it can easily rip, making the battery removal process harder.
  5. iPhone 4S Battery Replacement, Battery Removal: adım 5, 1 resimden 1.
    • Carefully remove the battery.
    • Remember, if you are replacing your battery, remember to preform a hard reset on your iPhone by holding on both the home and power button for a few seconds once the repair is all finished.
    hello my I phone4s dead so help me
    Ajay Sankhyan - Yanıt
    send me your what's app number
Sonuç
62 farklı kişi bu kılavuzu tamamladı.
Cole Anello
2.028 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
la olum bunu benim 1 yaşında kızım da biliyo
ahmetceylanbm - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 42
Son 30 gün: 391
Her zaman: 22,723
