Ana içeriğe geç
iPhone 4S Headphone Jack Cable Assembly Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. iPhone 4S Headphone Jack Cable Assembly Replacement, Headphone Jack Cable Assembly: adım 1, 3 resimden 1. iPhone 4S Headphone Jack Cable Assembly Replacement, Headphone Jack Cable Assembly: adım 1, 3 resimden 2. iPhone 4S Headphone Jack Cable Assembly Replacement, Headphone Jack Cable Assembly: adım 1, 3 resimden 3.
    • In this step, be careful not to remove the headphone jack without first separating the top microphone from the upper case, as they are connected by a fragile flex cable.
    • Use a plastic opening tool to start to pry the headphone jack out of its recess in the rear case.
    • Then use the opening tool to gently peel the microphone up from the adhesive securing it to the top of the rear case.
    • Remove the headphone jack assembly from the rear case, being careful not to tear the microphone flex cable.
  2. iPhone 4S Headphone Jack Cable Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the 1.6 mm Phillips screw securing the mute switch bracket to the outer case.
  3. iPhone 4S Headphone Jack Cable Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the four 1.5 mm Phillips screws securing the volume button and silent switch brackets to the outer case.
  4. iPhone 4S Headphone Jack Cable Assembly Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to gently pull the silent switch bracket away from the outer case.
  5. iPhone 4S Headphone Jack Cable Assembly Replacement: adım 5, 1 resimden 1.
    • Carefully peel the headphone jack/volume button cables off the adhesive securing them to the rear case.
    • Remove the headphone jack cable assembly from the iPhone.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 1,809
