Ana içeriğe geç
Giriş
Internal prerequisite.
Parçalar
Hiçbir parça belirtilmedi.
  1. Use the edge of a plastic opening tool to pry the earpiece speaker off the adhesive securing it to the outer case. Note that the power button cable is glued to the the case as well, and will need to be pried up. Use a pair of tweezers to unfold the earpiece speaker from its recess in the outer case.
    • Use the edge of a plastic opening tool to pry the earpiece speaker off the adhesive securing it to the outer case. Note that the power button cable is glued to the the case as well, and will need to be pried up.
    • Use a pair of tweezers to unfold the earpiece speaker from its recess in the outer case.
    • Be careful not to tear the cable from the earpiece speaker. They are adhered together, and the cable is very delicate.
  2. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Hemen Alışveriş Yapın
    iPhone X Fix Kits
  3. Use the edge of plastic opening tool to  gently move the top sensor assembly away from the outer case. Gently pry the top sensor assembly off the outer case.
    • Use the edge of plastic opening tool to gently move the top sensor assembly away from the outer case.
    • Gently pry the top sensor assembly off the outer case.
  4. Lift and remove the power and sensor cable assembly from the iPhone. Be sure not to lose the small retainer clip located on the top sensor assembly. Be sure not to lose the small retainer clip located on the top sensor assembly.
    • Lift and remove the power and sensor cable assembly from the iPhone.
    • Be sure not to lose the small retainer clip located on the top sensor assembly.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 789
