Ana içeriğe geç
iPhone 4S Speaker Enclosure Assembly Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. iPhone 4S Speaker Enclosure Assembly Replacement, Speaker Enclosure Assembly: adım 1, 2 resimden 1. iPhone 4S Speaker Enclosure Assembly Replacement, Speaker Enclosure Assembly: adım 1, 2 resimden 2.
    • Remove the following screws securing the dock connector cable cover to the logic board:
    • One 1.5 mm Phillips screw
    • One 1.2 mm Phillips screw
    • Remove the metal dock connector cable cover.
  2. iPhone 4S Speaker Enclosure Assembly Replacement: adım 2, 1 resimden 1.
    • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
  3. iPhone 4S Speaker Enclosure Assembly Replacement: adım 3, 1 resimden 1.
    • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
  4. iPhone 4S Speaker Enclosure Assembly Replacement: adım 4, 2 resimden 1. iPhone 4S Speaker Enclosure Assembly Replacement: adım 4, 2 resimden 2.
    • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
    • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
  5. iPhone 4S Speaker Enclosure Assembly Replacement: adım 5, 1 resimden 1.
    • Remove the two 2.4 mm Phillips screws securing the speaker enclosure assembly to the outer case.
  6. iPhone 4S Speaker Enclosure Assembly Replacement: adım 6, 1 resimden 1.
    • Remove the small black spacer that was under the Phillips screw near the vibrator.
  7. iPhone 4S Speaker Enclosure Assembly Replacement: adım 7, 3 resimden 1. iPhone 4S Speaker Enclosure Assembly Replacement: adım 7, 3 resimden 2. iPhone 4S Speaker Enclosure Assembly Replacement: adım 7, 3 resimden 3.
    • Use a plastic opening tool to lift the speaker enclosure assembly out of the case, being sure not to damage the EMI fingers on the attached Wi-Fi antenna.
    • Remove the speaker enclosure assembly.
    • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the third picture.
    • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 746
