Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to remove the earpiece speaker in your iPhone 5.
Neye ihtiyacın var
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
Regardless of the tool you use, you need to be sure you pull up the entire display.
If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
Bu adımda kullanılan alet:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
With a plastic opening tool, begin to gently pry the rear case down, away from the screen, while you pull up with the suction cup.
Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the following two screws securing the metal battery connector bracket to the logic board:
One 1.8 mm Phillips screw
One 1.6 mm Phillips screw
Remove the metal battery connector bracket from the iPhone.
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following screws securing the front panel assembly cable bracket to the logic board:
Two 1.2 mm Phillips screws
Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
Use a plastic opening tool or a fingernail to disconnect the three front panel assembly cables:
Front-facing camera and sensor cable
LCD cable
Digitizer cable
Remove the front panel assembly from the rear case.
Remove two screws securing the front-facing camera bracket to the display assembly.
One 4.1 mm Phillips screw
One 2.2 mm Phillips screw
200 farklı kişi bu kılavuzu tamamladı.
9 Yorum
Hello folks,
my iPhone stopped working, diagnostic as follow:
Need to switch to speaker or use headphones to call, since caller can hear me, but I cant.
Please tell me that its not a chip failure.
thx :)
I decided to examine the problem before ordering the new earpiece speaker, so performed the disassembly first. At Step 13, I found that one of the two screws holding the bracket was already completely loose. Everything else checked out visually (the spilled wine that I'd worried about was nowhere to be seen), so I reassembled. Bam! Working just fine, no new part needed.
worked for me also. issue was that the 2 gold coils on the back of the ear-piece (which you will see after you disassemble parts) were contracted. Simply extended them out a little by pulling with gentle force, this will re-enable them to earth properly against the gold plates.
GH Sales -
Also worked for me. iPhone 5C, 2 years old, ear speaker stopped working.
Like GH Sales all that was required was pulling on the two gold springs on the back of the earpiece speaker. This fixed the speaker problem for me.
Jakub -
Had the same issue, what GH Sales did worked for me!
