Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove three screws securing the vibrator and vibrator bracket to the rear case: One 2.3 mm Phillips screw
    • Remove three screws securing the vibrator and vibrator bracket to the rear case:
    • One 2.3 mm Phillips screw
    • One 1.7 mm Phillips screw
    • One 1.6 mm Phillips screw securing the vibrator to the top inside of the rear case.
  2. Remove the vibrator and vibrator bracket from the rear case.
    • Remove the vibrator and vibrator bracket from the rear case.
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. Remove the following screws securing the volume button and ringer switch brackets to the side of the rear case:
    • Remove the following screws securing the volume button and ringer switch brackets to the side of the rear case:
    • One 1.5 mm Phillips screw
    • Two 1.8 mm Phillips screws
  5. Use the tip of a spudger to pry the ringer switch bracket from the side of the rear case. Remove the ringer switch.
    • Use the tip of a spudger to pry the ringer switch bracket from the side of the rear case.
    • Remove the ringer switch.
  6. Use a spudger to pry the volume button bracket from the side of the rear case. Remove the volume buttons.
    • Use a spudger to pry the volume button bracket from the side of the rear case.
    • Remove the volume buttons.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Optimus Goldheart
448.953 İtibar
411 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
124 Üyeler
11.605 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 466
