Ana içeriğe geç
iPhone 5c Logic Board Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. iPhone 5c Logic Board Replacement, Logic Board: adım 1, 3 resimden 1. iPhone 5c Logic Board Replacement, Logic Board: adım 1, 3 resimden 2. iPhone 5c Logic Board Replacement, Logic Board: adım 1, 3 resimden 3.
    • Use a spudger to disconnect the Lightning connector ribbon cable from its socket on the logic board.
    • The Lightning connector cable is lightly adhered to a shield on the logic board. Use the flat end of a spudger to gently peel the cable up.
  2. iPhone 5c Logic Board Replacement: adım 2, 2 resimden 1. iPhone 5c Logic Board Replacement: adım 2, 2 resimden 2.
    • Flip the Lightning connector cable up out of the way of the logic board.
  3. iPhone 5c Logic Board Replacement: adım 3, 1 resimden 1.
    • Disconnect the lower antenna connector from the base of the logic board.
  4. iPhone 5c Logic Board Replacement: adım 4, 2 resimden 1. iPhone 5c Logic Board Replacement: adım 4, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the audio control cable connector from its socket on the logic board.
    • Disconnect the rear-facing camera cable connector from its socket on the logic board.
  5. iPhone 5c Logic Board Replacement: adım 5, 1 resimden 1.
    • A small piece of tape may obscure the logic board grounding clip. If so, use a pair of tweezers to remove the tape.
  6. iPhone 5c Logic Board Replacement: adım 6, 2 resimden 1. iPhone 5c Logic Board Replacement: adım 6, 2 resimden 2.
    • Remove the following screws securing the logic board grounding clip to the rear case:
    • 1.2 mm Phillips #000 in the top side-wall
    • 2.5 mm Phillips #000
  7. iPhone 5c Logic Board Replacement: adım 7, 1 resimden 1.
    • Use tweezers to remove the logic board grounding clip.
  8. iPhone 5c Logic Board Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    Standoff Screwdriver for iPhones
    $5.49
    Satın Al
    • Remove the following screws securing the logic board to the rear case:
    • Two 2.3 mm Phillips screws
    • Three 2.7 mm standoff screws
    • Standoff screws are best removed with a standoff screwdriver or standoff driver bit. A small flathead screwdriver can also do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  9. iPhone 5c Logic Board Replacement: adım 9, 3 resimden 1. iPhone 5c Logic Board Replacement: adım 9, 3 resimden 2. iPhone 5c Logic Board Replacement: adım 9, 3 resimden 3.
    • Holding the phone level, lift the bottom end of the logic board up enough to grasp it with your fingers.
    • Pull the logic board away from the rear-facing camera just enough to expose the gold contact cap under the top end of the board.
    • Remove the gold-colored contact cap from the threaded post in the rear case, and set it aside.
  10. iPhone 5c Logic Board Replacement: adım 10, 2 resimden 1. iPhone 5c Logic Board Replacement: adım 10, 2 resimden 2.
    • Flip the logic board up toward the volume control buttons to expose the antenna connector.
    • Do not try to remove the logic board from the rear case yet, as it is still connected by an antenna cable on the back.
  11. iPhone 5c Logic Board Replacement: adım 11, 1 resimden 1.
    • Disconnect the antenna connector from the back of the logic board.
  12. iPhone 5c Logic Board Replacement: adım 12, 1 resimden 1.
    • Remove the logic board from the rear case.
Sonuç
Andrew Optimus Goldheart
502.656 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.722 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 200
