Ana içeriğe geç
iPhone 5c Volume Controls Replacement
Neye ihtiyacın var
  1. iPhone 5c Volume Controls Replacement, Taping the display glass: adım 1, 3 resimden 1. iPhone 5c Volume Controls Replacement, Taping the display glass: adım 1, 3 resimden 2. iPhone 5c Volume Controls Replacement, Taping the display glass: adım 1, 3 resimden 3.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    FixBot'a Sor
  2. iPhone 5c Volume Controls Replacement, Removing the Pentalobe screws: adım 2, 1 resimden 1.
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.8 mm P2 Pentalobe screws on either side of the Lightning connector.
    FixBot'a Sor
  3. iPhone 5c Volume Controls Replacement, Starting the iSclack Opening Procedure: adım 3, 3 resimden 1. iPhone 5c Volume Controls Replacement, Starting the iSclack Opening Procedure: adım 3, 3 resimden 2. iPhone 5c Volume Controls Replacement, Starting the iSclack Opening Procedure: adım 3, 3 resimden 3.
    • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 5c that we recommend for anyone doing more than one repair on an iPhone 5, 5s, or 5c. If you aren't using the iSclack, skip to Step 5.
    • Close the handle on the iSclack, opening the suction-cup jaws.
    • Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
    • The top suction cup should rest just above the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
    FixBot'a Sor
  4. iPhone 5c Volume Controls Replacement, Finishing the iSclack Opening Procedure: adım 4, 2 resimden 1. iPhone 5c Volume Controls Replacement, Finishing the iSclack Opening Procedure: adım 4, 2 resimden 2.
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on to Step 8.
    FixBot'a Sor
  5. iPhone 5c Volume Controls Replacement, Manual Opening Procedure: adım 5, 1 resimden 1.
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    FixBot'a Sor
  6. iPhone 5c Volume Controls Replacement, Start lifting the front panel assembly: adım 6, 2 resimden 1. iPhone 5c Volume Controls Replacement, Start lifting the front panel assembly: adım 6, 2 resimden 2.
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
    FixBot'a Sor
  7. iPhone 5c Volume Controls Replacement: adım 7, 1 resimden 1.
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
    FixBot'a Sor
  8. iPhone 5c Volume Controls Replacement, Opening up the phone: adım 8, 2 resimden 1. iPhone 5c Volume Controls Replacement, Opening up the phone: adım 8, 2 resimden 2.
    • Lift the home button end of the front panel up to gain access to the connectors near the top of the phone.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, you can use an unopened canned beverage to hold the display.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    FixBot'a Sor
  9. iPhone 5c Volume Controls Replacement: adım 9, 1 resimden 1.
    • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
    FixBot'a Sor
  10. iPhone 5c Volume Controls Replacement: adım 10, 1 resimden 1.
    • Remove the metal battery connector bracket from the iPhone.
    FixBot'a Sor
  11. iPhone 5c Volume Controls Replacement, Disconnecting the battery connector: adım 11, 1 resimden 1.
    • Use a spudger or a clean fingernail to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
    FixBot'a Sor
  12. iPhone 5c Volume Controls Replacement: adım 12, 1 resimden 1.
    • Remove the following Phillips #000 screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.3 mm screws
    • One 1.7 mm screw
    • One 3.25 mm screw
    • It is especially important to keep track of your screws in this step for reassembly. Accidentally using the 3.25 mm screw or the 1.7 mm screw in the bottom right hole will result in significant damage to the logic board causing the phone to no longer boot properly.
    • Be careful not to over-tighten the screws. If they don't fit easily when you are securing them, they may be the wrong size—don't force them.
    FixBot'a Sor
  13. iPhone 5c Volume Controls Replacement: adım 13, 1 resimden 1.
    • Remove the front panel assembly cable bracket from the logic board.
    FixBot'a Sor
  14. iPhone 5c Volume Controls Replacement, Disconnecting the front panel assembly cables: adım 14, 2 resimden 1. iPhone 5c Volume Controls Replacement, Disconnecting the front panel assembly cables: adım 14, 2 resimden 2.
    • Use a plastic opening tool or a fingernail to disconnect the front-facing camera and sensor cable connector.
    • Be sure to only pry up on the connector, and not on the socket on the logic board.
    FixBot'a Sor
  15. iPhone 5c Volume Controls Replacement: adım 15, 3 resimden 1. iPhone 5c Volume Controls Replacement: adım 15, 3 resimden 2. iPhone 5c Volume Controls Replacement: adım 15, 3 resimden 3.
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a plastic opening tool or a fingernail to disconnect the LCD cable connector.
    • The LCD and Digitizer connectors are on the same cable assembly, so prying the LCD connector up should disconnect both connectors. Double check that the two cables are fully disconnected before removing the display.
    • When reassembling your phone, the LCD cable may pop off its connector. A blank screen, or white lines on the display could be caused by a loose connection. Should this happen, reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
    FixBot'a Sor
  16. iPhone 5c Volume Controls Replacement, Separating front panel assembly and rear case: adım 16, 1 resimden 1.
    • Remove the front panel assembly from the rear case.
    FixBot'a Sor
  17. iPhone 5c Volume Controls Replacement, SIM Card: adım 17, 2 resimden 1. iPhone 5c Volume Controls Replacement, SIM Card: adım 17, 2 resimden 2.
    • Shut your phone down completely before removing the SIM card and tray.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press the SIM card eject tool inwards to eject the tray.
    • This may require a significant amount of force.
    FixBot'a Sor
  18. iPhone 5c Volume Controls Replacement: adım 18, 1 resimden 1.
    • Remove the SIM Card tray assembly from the iPhone.
    • During reassembly, ensure that the SIM card is in the proper orientation relative to the tray.
    FixBot'a Sor
  19. iPhone 5c Volume Controls Replacement, Battery: adım 19, 3 resimden 1. iPhone 5c Volume Controls Replacement, Battery: adım 19, 3 resimden 2. iPhone 5c Volume Controls Replacement, Battery: adım 19, 3 resimden 3.
    • Run the tip of a spudger between the battery and the headphone jack to unfold the battery adhesive tab.
    FixBot'a Sor
  20. iPhone 5c Volume Controls Replacement: adım 20, 1 resimden 1.
    • Pull the battery adhesive tab away from the phone.
    FixBot'a Sor
  21. iPhone 5c Volume Controls Replacement: adım 21, 2 resimden 1. iPhone 5c Volume Controls Replacement: adım 21, 2 resimden 2.
    • Cut the black battery adhesive tab between the two white adhesive strips, separating them.
    FixBot'a Sor
  22. iPhone 5c Volume Controls Replacement: adım 22, 2 resimden 1. iPhone 5c Volume Controls Replacement: adım 22, 2 resimden 2.
    • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
    • Slowly pull one of the battery adhesive strips away from the battery, toward the bottom of the iPhone.
    • Pull steadily, maintaining constant tension on the strip as it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
    • Guide the strip carefully around the corner and up the side of the battery. Be careful not to snag it on any of the other internal iPhone components.
    • The strip will stretch to many times its original length. Continue pulling, re-grabbing the strip near the battery if necessary, until the entire strip comes free.
    FixBot'a Sor
  23. iPhone 5c Volume Controls Replacement: adım 23, 2 resimden 1. iPhone 5c Volume Controls Replacement: adım 23, 2 resimden 2.
    • Repeat to remove the second strip.
    FixBot'a Sor
  24. iPhone 5c Volume Controls Replacement: adım 24, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the battery from your iPhone.
    • If one, or both, of the adhesive strips tears, and you are unable to retrieve it with a set of tweezers, do not pry the battery out of the phone. Continue on to the next steps to safely remove your battery.
    FixBot'a Sor
  25. iPhone 5c Volume Controls Replacement, Battery removal with latent adhesive: adım 25, 2 resimden 1. iPhone 5c Volume Controls Replacement, Battery removal with latent adhesive: adım 25, 2 resimden 2.
    Plastic Cards
    $2.99
    • Apply a few drops of isopropyl alcohol (90% or greater) under the battery and let it flow around the adhesive to help weaken it. High concentration isopropyl alcohol acts as a solvent and dries without leaving any residue, so it will not hurt your iPhone.
    • Carefully wedge a plastic card under the battery on the side nearest the logic board.
    • Do not pry against the logic board or you may damage the phone.
    • Avoid prying near the top edge of the battery, or you may damage the upper component ribbon cable.
    • Slide the card from the top of the battery to the bottom, pushing toward the edge of the case.
    • If necessary, repeat the same procedure with the case side of the battery.
    FixBot'a Sor
  26. iPhone 5c Volume Controls Replacement: adım 26, 1 resimden 1.
    • If the battery is still stuck to the case, follow our iOpener heating instructions or use a hair dryer to heat the adhesive securing your battery to the rear case.
    • Lay the iOpener flat on the backside of the iPhone to the right of the camera. Smooth it out so that there is good contact between the back of the iPhone and the iOpener.
    • Let the bag sit on the iPhone for approximately 90 seconds before attempting to remove the battery.
    • If using a hair dryer or heat gun, heat the back of the iPhone until it's slightly too hot to touch.
    • Do not apply heat directly to the battery.
    • Overheating the iPhone may ignite the battery.
    FixBot'a Sor
  27. iPhone 5c Volume Controls Replacement: adım 27, 1 resimden 1.
    • Lift and remove the battery from the iPhone.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • There should be no resistance. If the battery remains stuck, reheat the iOpener and pry again.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
    • Before you adhere the replacement battery, temporarily reconnect the battery connector to the motherboard socket. This ensures that the battery is properly aligned in its recess.
    • Adhere the battery, disconnect it, and continue reassembling your device.
    • If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
    FixBot'a Sor
  28. iPhone 5c Volume Controls Replacement, Volume Controls: adım 28, 1 resimden 1.
    • Remove the two 1.6 mm Phillips #000 screws from the hold switch bracket.
    FixBot'a Sor
  29. iPhone 5c Volume Controls Replacement: adım 29, 2 resimden 1. iPhone 5c Volume Controls Replacement: adım 29, 2 resimden 2.
    • Remove this hold button bracket clip and set it aside.
    • During reassembly, ensure the angled portion is to the right.
    • Use the tip of a spudger to flip the hold switch bracket down.
    FixBot'a Sor
  30. iPhone 5c Volume Controls Replacement: adım 30, 1 resimden 1.
    • Use tweezers to remove the hold switch.
    • Note the orientation for reassembly: The red line should be at the top of the button. The notch in the back of the hold switch button should be in the same position as, and mate with, the mechanical switch on the cable.
    FixBot'a Sor
  31. iPhone 5c Volume Controls Replacement: adım 31, 1 resimden 1.
    • Remove the 1.6 mm Phillips #000 screw securing the volume rocker bracket to the side wall.
    FixBot'a Sor
  32. iPhone 5c Volume Controls Replacement: adım 32, 2 resimden 1. iPhone 5c Volume Controls Replacement: adım 32, 2 resimden 2.
    • Use the tip of a spudger to fold the volume rocker bracket down from the side wall.
    • Remove the volume rocker.
    FixBot'a Sor
Sonuç
25 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
514.904 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
25.718 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thank you a million times over. Without yoyr guide I eould never know where that easher wehtvon thevmute swutch. I sesrched for days and no other guide covered that. Bb you saved je a bigger headache
sharon - Yanıt Paylaş
r u having a seizure or smthin?
luca - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 20
Son 30 gün: 101
Her zaman: 17,993
