Giriş
Prerequisite for removing the battery after the logic board.
Neye ihtiyacın var
Insert the tip of a spudger into the hole in the battery adhesive tab near the headphone jack.
Lift the tab up slightly and use the spudger to unfold the tab from its recess.
If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
Bu adımda kullanılan alet:Plastic Cards$2.99
Flip the iPhone back over and insert a plastic card between the case side of the battery and the rear case.
Press the card in farther to break up the adhesive behind the battery.
18 farklı kişi bu kılavuzu tamamladı.
2 Yorum
I feel like this guide should at least start with a link to another guide on opening up your phone. It’s weird that it just jumps in assuming your phone has already been opened. From a UX perspective, I should have to hunt around for a preceding guide when the topic of this one shows up on the top of my search results and describes exactly what I want to do.
Use this battery guide to replace your battery. This guide is a prerequisite to remove the battery in the course of another repair, and isn’t meant to be followed on its own.
