Ana içeriğe geç
iPhone 5s Display Assembly Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. iPhone 5s Display Assembly Replacement, Display Assembly: adım 1, 1 resimden 1.
    • Remove pentalobe screws with torx screwdriver.
  2. iPhone 5s Display Assembly Replacement: adım 2, 2 resimden 1. iPhone 5s Display Assembly Replacement: adım 2, 2 resimden 2.
    • After using spudger or suction cup to lift screen. Be careful not to pull screen completely up. The touch id sensor flex cable is attached near the home button. There is a small metal clip that needs to be carefully pry'd off before removing flex cable connector.
  3. iPhone 5s Display Assembly Replacement: adım 3, 2 resimden 1. iPhone 5s Display Assembly Replacement: adım 3, 2 resimden 2.
    • Disconnect battery before screen removal by removing 2 screws from shield. Once shield is removed, disconnect battery using nylon spudger. (DO NOT USE METAL TOOLS)
  4. iPhone 5s Display Assembly Replacement: adım 4, 3 resimden 1. iPhone 5s Display Assembly Replacement: adım 4, 3 resimden 2. iPhone 5s Display Assembly Replacement: adım 4, 3 resimden 3.
    • Remove four screws from shield covering display assembly connectors. Lift connectors using nylon spudger.
Sonuç
Swap all parts from old display assembly to new assembly. Do not remove all at once, replace components one at a time. To reassemble your device, follow these instructions in reverse order.
57 farklı kişi bu kılavuzu tamamladı.
Fausto Lebron
4.119 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 21
Her zaman: 32,637
