Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Bu adımda kullanılan alet:iOpener$19.99-
Using an iOpener to soften the adhesive will help safely remove it. Follow our iOpener instructions to use it.
Using the edge of a set of tweezers or a metal spudger, gently pry the earpiece speaker contact cable up, to separate this portion of the camera and sensor cable from the adhesive below.
Use the point of a spudger to lift the ambient light sensor and proximity sensor out of their recess in the display assembly.
Use the flat end of a spudger to gently peel the front-facing camera portion of the cable away from the display assembly.
Carefully peel the cable assembly off of the LCD shield plate to remove it from the display.
9 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Be great if someone could put together some *reassembly* instructions for this. Particularly the section on the camera and sensors area.
It seems like a lot of steps have gone missing from this guide. The related guide (5SE) has much more explicit instructions for the same activity and should be used instead of this one. iPhone SE Front Facing Camera and Sensor Cable Replacement
