Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. iPhone 5s cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. iPhone 5s Teardown, iPhone 5s Teardown: adım 1, 3 resimden 1. iPhone 5s Teardown, iPhone 5s Teardown: adım 1, 3 resimden 2. iPhone 5s Teardown, iPhone 5s Teardown: adım 1, 3 resimden 3.
    • An iPhone release means a trip to the future—the iFixit teardown crew has traveled 17 hours forward in time to get the iPhone 5s early.
    • We want to send out a big thanks to our good friends at MacFixit Australia for letting us use their office in Melbourne for the teardown. They stock Mac and iPhone upgrades/accessories, and also carry our iFixit toolkits.
    • To cover all our bases, we confirmed with our best linguists that the 5s upside-down is still the 5s.
    • Speaking of toolkits, for this teardown, we'll be using iFixit's brand-new Pro Tech Screwdriver Set.
  2. iPhone 5s Teardown: adım 2, 2 resimden 1. iPhone 5s Teardown: adım 2, 2 resimden 2.
    • As we ready ourselves to delve into the delightful innards of the 5s, let's check out some of its tech specs:
    • Apple A7 processor with 64-bit architecture
    • M7 motion co-processor
    • 16, 32, or 64 GB Storage
    • 4-inch retina display with 326 ppi
    • 8 MP iSight camera (with larger 1.5µ pixels) and a 1.2MP FaceTime camera.
    • Fingerprint identity sensor built into the home button
    • Available in three different colors: space gray, silver, and gooooooold (or as we call them, Not-at-all-the-Color-of-Space, Second Place Medal, and Bling!).
  3. iPhone 5s Teardown: adım 3, 3 resimden 1. iPhone 5s Teardown: adım 3, 3 resimden 2. iPhone 5s Teardown: adım 3, 3 resimden 3.
    • Apple continues the everlasting trend of locking users out with pentalobular screws. Luckily, we came prepared. We whip out our trusty iPhone 5 Liberation Kit, and to our pleasant surprise, it works!
    • Unfortunately, we are ill-equipped in the color department, as we only have silver and black replacement Phillips screws.
    • We are currently involved in heavy lobbying to our product designers to create 14k gold replacement screws. They'll be $50 each and strip the first time you try to unscrew them, so they will be perfect for the iPhone. Stay posted.
    • With our iPhone 5s sufficiently liberated, it reminds us of another polka-dotted iPhone teardown coming in the near future…
  4. iPhone 5s Teardown: adım 4, 2 resimden 1. iPhone 5s Teardown: adım 4, 2 resimden 2.
    • We're done screwing around; it's time to get this baby open! Just like last year, we enlist the help of a suction cup to free the display assembly from the rear casing.
    • Unlike last year, we make use of some gentle spudgering, just in case…
  5. iPhone 5s Teardown: adım 5, 3 resimden 1. iPhone 5s Teardown: adım 5, 3 resimden 2. iPhone 5s Teardown: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Spudger
    $3.99
    • Our careful spudgering paid off. At the bottom of the phone, a cable connects the Touch ID sensor in the home button to the Lightning port assembly.
    • This adds a small element of danger to disassembly, as pulling too hard on the suction cup could cause accidental damage to the cable.
    • We survive this first booby trap and swiftly disconnect the Touch ID cable connector with the help of a spudger.
    • Alas, our first peek at the internal layout of the 5s. Comparing it to the iPhone 5, we spot very few differences, the main one being the lack of a battery removal pull-tab.
  6. iPhone 5s Teardown: adım 6, 3 resimden 1. iPhone 5s Teardown: adım 6, 3 resimden 2. iPhone 5s Teardown: adım 6, 3 resimden 3.
    iOpener
    $17.99
    • With our favorite screwdriver set, we remove a few metal connector covers and embark on the epic battle of battery removal.
    • The missing battery pull-tab, though seemingly innocuous, indicates a bigger problem for battery repair: glue.
    • Perhaps the "s" in 5s stands for "stuck," as in "this battery is stuck in with a lot of glue," or "I hope you didn't want to replace your battery—you're going to be stuck with this one."
    • While we'd love a tool-less battery removal as we've seen in other phones, we settle for thermal battery removal via an iOpener.
    • Holy adhesive! It appears Apple ditched the minimal adhesive in the iPhone 5 in favor of those two huge white runways of adhesive holding the 5s(tuck) battery in place.
    • Update: Lots of folks notified us of the peel-able nature of the adhesive strips. We've acquired more iPhones for the repair guides, and we'll adjust the repair score (if needed) once we investigate the issue!
  7. iPhone 5s Teardown: adım 7, 3 resimden 1. iPhone 5s Teardown: adım 7, 3 resimden 2. iPhone 5s Teardown: adım 7, 3 resimden 3.
    • The 5s has a claimed 10 hours of talk time on 3G, but there are rumbles that iOS 7 isn't doing you any favors.
    • The gold unit from Desay Battery Co., Ltd in Huizhou, China sports a 3.8V - 5.92Wh - 1560 mAh battery. Comparatively:
    • iPhone 5: 3.8 V - 1440 mAh - 5.45 Wh. Talk time: Up to 8 hours on 3G. Standby time: Up to 225 hours.
    • Samsung Galaxy S4: 3.8 V - 2600 mAh - 9.88 Wh. Talk time: up to 7 hours. Standby time: Up to 300 hours.
    • Motorola Moto X: 3.8 V - 2200 mAh - 8.4 Wh. 24 hours of "mixed usage."
    • It appears different units sport different battery manufacturers; our "space-gray" spare (right) comes to us from Simplo Technology Inc.
  8. iPhone 5s Teardown: adım 8, 2 resimden 1. iPhone 5s Teardown: adım 8, 2 resimden 2.
    • With the battery safely removed, we turn to the next step in our disassembly journey: removing the (unchanged) 326 ppi Retina display assembly.
    • A few flicks of a spudger to disconnect the FaceTime camera, digitizer, and LCD cables, and the display is free.
    • Looking for some tech specs on the display? Well look no further! In fact, just look backwards…to the iPhone 5. Despite the trend in almost every other smartphone release, the iPhone 5s display is no bigger, better, or badder than the 5.
  9. iPhone 5s Teardown: adım 9, 3 resimden 1. iPhone 5s Teardown: adım 9, 3 resimden 2. iPhone 5s Teardown: adım 9, 3 resimden 3.
    • We quickly extract the home button and Touch ID, Apple's new fingerprint scanner. Time to dust for prints!
    • A CMOS chip, the Touch ID is essentially a bunch of very small capacitors that creates an "image" of the ridges on your finger.
    • The sensor technology, developed by AuthenTec and bought by Apple a year ago, reportedly stores your fingerprints locally, so giving your iPhone the finger will not make it all the way back to Cupertino.
    • We worry about how well the sapphire crystal covering the sensor can protect it from degrading over time like most CMOS fingerprint sensors. If not, it could become a ticking time bomb, just like that super-glued battery.
  10. iPhone 5s Teardown: adım 10, 3 resimden 1. iPhone 5s Teardown: adım 10, 3 resimden 2. iPhone 5s Teardown: adım 10, 3 resimden 3.
    • We uncover the iSight camera.
    • The back of the iSight camera is labeled DNL333 41WGRF 4W61W.
    • According to our good friend Jim Morrison, Vice President of the Technology Analysis Group at Chipworks, "the DNL markings are consistent with the markings on the camera modules housing the Sony IMX145 we saw in the iPhone 4s and on the iPhone 5. The marks on the side of the module are different, but our industry insiders tell us this is Sony's again."
    • As Apple has stated the pixel pitch on this camera is 1.5 µ, this sensor should not be the IMX145, but a newer variant.
    • The bottom of the camera is labeled AW32 65BD 4511 b763.
  11. iPhone 5s Teardown: adım 11, 2 resimden 1. iPhone 5s Teardown: adım 11, 2 resimden 2.
    • For those of us counting steps and comparing with last year, we're unsurprisingly right on par.
    • A great example of Apple's iterative design, the 5s shows some streamlining and optimization in its internal construction.
    • Gone are those silly antenna interconnect cables, leaving one less thing to break or get accidentally disconnected.
    • If only they had decided to move that antenna connector from the bottom of the logic board to the top...
  12. iPhone 5s Teardown: adım 12, 2 resimden 1. iPhone 5s Teardown: adım 12, 2 resimden 2.
    • Looks like we found a Murata 339S0205 Wi-Fi module (based on the Broadcom BCM4334, according to Chipworks).
    • Again comparing our 16 and 64 GB models:
    • It seems that the Murata IC is the same between both iPhone 5s'.
    • The design of both logic boards may be identical, but slight differences in markings (e.g. 94V-0 on the rightmost, nonexistent on the leftmost) may indicate that Apple is manufacturing the 5s logic boards at multiple locations.
  13. iPhone 5s Teardown: adım 13, 1 resimden 1.
    • Open ses-EMI! Behold, IC treasures identified:
    • SK Hynix H2JTDG8UD3MBR 128 Gb (16 GB) NAND Flash
    • Qualcomm PM8018 RF power management IC
    • TriQuint TQM6M6224
    • Apple 338S1216
    • Broadcom BCM5976 touchscreen controller
    • Texas Instruments 343S0645 touchscreen interface
    • Skyworks 77810
  14. iPhone 5s Teardown: adım 14, 2 resimden 1. iPhone 5s Teardown: adım 14, 2 resimden 2.
    • More ICs!
    • Skyworks 77355
    • Avago A790720
    • Avago A7900
    • Apple 338S120L
    • A super-awesome thanks to the Chipworks team for helping us decode and discern these delightful devices!
  15. iPhone 5s Teardown: adım 15, 1 resimden 1.
    • Turning our attention to the backside of the logic board:
    • Apple A7 APL0698 SoC (based on this MacRumors post, the markings F8164A1PD indicate the RAM is likely 1GB)
    • Qualcomm MDM9615M LTE Modem
    • Qualcomm WTR1605L LTE/HSPA+/CDMA2K/TDSCDMA/EDGE/GPS transceiver.
    • As we search for a much-anticipated M7 coprocessor, we begin to wonder if it actually is a separate IC, or if it is additional functionality built into the A7.
    • Maybe the "M" stands for "magical," the M7 is invisible, and Apple does use pixie dust to hold the device together. Or perhaps the "M" stands for "marketing"…
    • Update: the M7 has been found!.
    • Our A7 was fabbed in July.
  16. iPhone 5s Teardown: adım 16, 2 resimden 1. iPhone 5s Teardown: adım 16, 2 resimden 2.
    • It's time to investigate the new kid on the block, and it's fly like an A7. Along with the fingerprint sensor, the A7 is a major enticement for consumers to pick the 5s over the 5c.
    • The A7 is advertised as providing twice the performance of the 5 (and 5c)'s A6 processor.
    • The switch to the A7 marks the first use of a 64-bit processor in a smartphone. Based on AnandTech's review, it seems that the bulk of the A7's performance gains do not come from any advantages inherent to a 64-bit architecture, but rather from the switch from the outdated ARMv7 instruction set to the newly-designed ARMv8.
    • The modern ARMv8 instruction set was designed for a 64-bit architecture. It does away with the legacy support of the last 20 years, which increases efficiency, improving performance without sacrificing battery life.
    • We'll have to wait until we get inside the chip to find out who manufactured it.
  17. iPhone 5s Teardown: adım 17, 2 resimden 1. iPhone 5s Teardown: adım 17, 2 resimden 2.
    • Time for your close-up, selfie cam!
    • A few screws hold the 1.2MP FaceTime camera in place.
    • While the updated pixel size in the iSight camera may get a lot of attention, DIY paparazzi is what bling iPhones are all about.
  18. iPhone 5s Teardown: adım 18, 3 resimden 1. iPhone 5s Teardown: adım 18, 3 resimden 2. iPhone 5s Teardown: adım 18, 3 resimden 3.
    • The lower peripherals on the 5s look very similar to those in the 5, though the speaker assembly comes out with slightly more ease in this iteration.
    • With the speaker assembly out, the headphone jack/microphone/Lightning connector assembly comes out easily.
    • As with previous generations, you will have to replace multiple components at once, since the design is not modular.
  19. iPhone 5s Teardown: adım 19, 2 resimden 1. iPhone 5s Teardown: adım 19, 2 resimden 2.
    • We find another hardware update: the new dual flash.
    • White and amber LEDs sit by the camera to balance the flash-induced ghostly tones of night-life photography.
  20. iPhone 5s Teardown: adım 20, 2 resimden 1. iPhone 5s Teardown: adım 20, 2 resimden 2.
    • iPhone 5s Repairability: 6 out of 10 (10 is easiest to repair)
    • Just like in the iPhone 5, the display assembly is the first component out of the phone, simplifying screen replacements.
    • The battery is still fairly easy to access, even though it's not technically "user replaceable."
    • The fingerprint sensor cable could be easily ripped out of its socket if a user is not careful while opening the phone.
    • The iPhone 5s still uses Pentalobe screws on the exterior, making the 5s difficult to open.
    • The front glass, digitizer, and LCD are all one component, thereby increasing cost of repair.
64Kılavuz Yorumları
Good Morning or Good Night All........Any hint yet of the Mfg of the 5S Gyroscope Accelerometer?
Will Kevlar - Yanıt
Yeah, anyone knows?
Mathieu Liong -
They forgot to peel the black sticker between the connectors, pretty sure it's beneath it
Tom Chai -
Hi, if you could remove the lens cover of the flash LED to expose the internal Flash LED component, it will be perfect.
Chin Ewe Phang - Yanıt
Another great guide thank you. Will the 5S rear camera fit the 5 and work?
dave - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 21
Son 7 gün: 148
Son 30 gün: 923
Her zaman: 1,359,468
