Giriş
Use this guide to strip and replace your cracked or broken iPhone 6 Plus screen. It will show you how to remove the home button, front-facing camera and sensor assembly, LCD shield plate, and home button ribbon cable—all of which will need to be transferred to your replacement panel. To replace the entire assembly instead, follow this much shorter guide.
In either case, it's important to transfer the original home button onto the new display in order for Touch ID (fingerprint scanning) to function.
Videoya Genel Bakış
Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
  • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
  • Power off your iPhone before beginning disassembly.
  • Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
I prefer to remove the SIM card as the very first step since it's safer to do so while the phone is fully assembled.
estebanfallasf - Yanıt
I stripped one of the two screws - at a dead stop.
Margaret Patterson - Yanıt
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass. Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered. This will keep glass shards contained and provide structural integrity when prying and lifting the display.
  • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
  • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
  • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
Tape doesn’t hold. suction cup doesn’t work. Tape folded over doesn’t work as a handle. I’ve used 3m’ s Gorilla duct tape. The glass is so shattered I cant get a point started to remove the glass. Phone has been in an otter box for years. dropped it and shattered glass while replacing case. Now what?
Martin Speedy - Yanıt
When all else fails, you can superglue your suction cup (or tape) to the display, wait for it to cure, and pull.
Jeff Suovanen -
  • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 6 Plus that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip to Step 4.
  • If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus.
  • Close the handle on the iSclack, opening the suction cup jaws.
  • Place the bottom of your iPhone in between the suction cups.
    • Position the iSclack's upper suction cup against the display, near the home button.
  • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
Yorum Ekle
Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case. The iSclack is designed to safely open your iPhone enough to separate the pieces, but not enough to damage any of the display cables.
  • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
  • The iSclack is designed to safely open your iPhone enough to separate the pieces, but not enough to damage any of the display cables.
  • Peel the two suction cups off your iPhone.
  • Skip the next three steps and continue on to Step 7.
It's very difficult if you want to remove a cracked screen. The suction cup and Islack won't work. Does anybody know a better way?
Herbert - Yanıt
I don't recommend replacing the home button. HOWEVER, I would purchase an iSesamo tool (I paid $8 for a 3 pack on FleaBay) and jam that in between the frame and bezel. Most effective way to open a iPhone. Once you get used to it an iSesamo becomes an extension of your arm.
iRevive Mobile -
I use Scotch Tape, shipping tape. Put a couple of layers over the crack screen. That seals it so you can use the suction cup to remove the front of phone.
Michael Wallace -
I used the plastic pry took and the spudger to open it up. I place the pry tool dead center below the home button and was able to put some pressure around the seam and the top popped up enough for me to get the spudger in there to hold it open and then work my way around with the plastic pry tool.
johnoconna -
Apply clear packaging tape to screen. Then suction cup to that.
Tracey -
Use clear nontextured tape place that over the phone screen. Refer to any guide that addresses replacing a shattered screen
Abigail Cherry - Yanıt
I know it's tough with cracked glass. You just need enough to get in a plstic pry tool or guitar pick. Then you can pry it apart. Just be patient, I cannot stress that enough; the electronics are very, very small and fragile.
Mike - Yanıt
If you don't have an iSclack, use a single suction cup to lift the front panel:
  • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
Avec la ventouse, l’ouverture est brutale, tout s’est déclipsé d’un seul coup. Faire attention.
Paul Briffaut - Yanıt
English Please!
tom mozeleski -
With the sucker, the opening is brutal, everything was cleared at once. Pay attention. (Paul’s comment translated by Google)
Steve Schlotter - Yanıt
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
  • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
  • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
  • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
Be extra careful here. If you don’t take your time, your front panel may jerk back on you, causing you to overextend and break the front camera/mic flex cable; happened to me. Slowly peel back the front panel, opening it no more than 90º.
Thomas - Yanıt
watch out for the left side of the phone the adhesive bunches up around the inner clips, i didn’t realize it and the upper left of my screen cracked pretty bad. But this guide is awesome follow every direction to the letter
Aaron Fitzpatrick - Yanıt
Pull the plastic nub to release the vacuum seal on the suction cup. Remove the suction cup from the display assembly.
  • Pull the plastic nub to release the vacuum seal on the suction cup.
  • Remove the suction cup from the display assembly.
Yorum Ekle
Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge. Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone. Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  • Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
  • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
Be careful If we leave the screen connected and set it to 90 degrees, the speaker / sensor flex may break. With an opening of 60 degrees it is convenient to completely disconnect the screen. The headset's flex is short, and if we put it at 90º, it can break. Guiding me from the images of iFixit, I have broken two cables.
Español:
Cuidado. Si dejamos la pantalla conectada y lo ponemos a 90 grados, el flex del altavoz/sensor puede romperse. Con una abertura de 60 grados es conveniente desconectar enteramente la pantalla. El flex del auricular es corto, y si lo ponemos en 90º , se puede romper. Guiándome de las imágenes de iFixit, se me han roto dos cables.
txaukos - Yanıt
At 60º the display will block access to all the screws and the phone would be practically unserviceable, so I’m having trouble making sense of this comment. The cables on a factory original display are pretty tough and designed with enough slack that a 90º angle is no problem. Same with any decent aftermarket display.
Jeff Suovanen - Yanıt
If you look at the enlarged image, you can see how the flex cable from the camera / speaker is in tension. This is my opinion. Sorry for my bad English
Si usted se fija en la imagen ampliada, puede ver cómo el flex cable de la cámara/altavoz está en tensión. Esta es mi opinión.
Perdón por mi mal inglés
txaukos - Yanıt
Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book. During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  • Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book.
  • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
I would recommend protecting the screen once the display is free and the suction cup has been removed. This will help avoid any possibility of accidental scratching of the display crystal while the remaining steps are being performed. I used an inexpensive screen protector then removed it after reassembling and testing are complete.
anthonyspampinato - Yanıt
Remove the following Phillips screws from the battery connector bracket:
  • Remove the following Phillips screws from the battery connector bracket:
    • One 2.3 mm screw
    • One 3.1 mm screw
for the iPhone 6 Plus, all screws were Phillips #000
Michael Adams - Yanıt
Thank you :)
Daniel Benet - Yanıt
The screw circled in red won't come out and I'm using a 1.2 screw driver
Sierra - Yanıt
I had difficulty removing the 3.1mm (iPhone 6 Plus / Phillips #000); had to give it significant downward pressure to get it started.
Allen Matheson - Yanıt
stripped the 2.3mm screw attempting to remove, had to use excessive force to successfully remove
Matthew Gao - Yanıt
The Phillips bits provided in the kit would not engage the Phillips heads enough to loosen them. Luckily I had my own small screwdriver set that worked like a charm.
David Davis - Yanıt
Remove the metal battery connector bracket from the iPhone.
  • Remove the metal battery connector bracket from the iPhone.
Was not able to remove the battery connector bracket as one of the cable connectors was glued/stuck to the underside. Instead moved the bracket out of the way to disconnect the battery. Care should be taken not to over bend/stretch the ribbon cable.
dwtan - Yanıt
That may be just the foam connector adhering to the bracket. If you pull up gently and twist slightly it should separate.
Evan Noronha -
It was the foam connector, and it did twist free with a gentle pull
Al Taylor - Yanıt
Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
  • Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
  • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
you may consider placing a thin non-conductive item between the connector and the socket like a bit of rubber band to prevent any power flowing during this procedure
It was too close to other parts to pry up with either end of plastic tool. Finally used 1 tine of tweezer to lift edge. Came free easily
Al Taylor - Yanıt
J’ai pris une loupe pour bien observer l’endroit où placer l’outil.
Magnification is key for many tasks and this is certainly one.
Kenneth Gilbert - Yanıt
Remove the following Phillips screws securing the front panel assembly cable bracket:
  • Remove the following Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.5 mm screw
    • One 2.9 mm screw
  • Do not attempt to insert longer screws into the red marked screw holes. Doing so may result in irreparable damage to the logic board.
There's an other panel with one screw in the middle.........
Herbert - Yanıt
I _love_ the color coding of screws. I know this is a little OCD, but it would be incredibly useful if there were an 8.5 X 11 you could print with indicated homes for where to drop items from each step of disassembly. That is, in the box for step 9, little colored circles for where to place each screw type. As long as you don't jostle the paper, it would make it a lot easier to know exactly where you are in reassembly.
cscarlson47shop - Yanıt
I have done the exact same thing. Created a sheet where each screw goes.
Chris Murphy -
On my iPhone 6 plus, none of the screws listed in this step are removable with the Phillips 00 screwdriver! I got this far and now am stymied because I can't get these four screws out! Any other screwdrivers I should use?
garth libhart - Yanıt
You are absolutely right, and you will strip the heads if you try very hard with the PH00. These screws are all PH000.
oscar -
I used the 000 bit from the ifixit 54 piece kit.
hhandh - Yanıt
Actually you don’t need to do steps 12 to 18 if you attach the display panel to the iPhone box as shown in step 7 and handle your iPhone with care during the replacement. I didn’t disconnect the display panel mainly because the more you work on the interior of your phone the higher is the chance you break something.
Dany Castillo - Yanıt
That's what I was thinking.
The Wizard - Yanıt
I skipped this series of steps too. I was very careful when removing the battery and never had an issue with the screen leaning back against the box that this battery shipped in. I even broke half of the third strip of adhesive but used a plastic card to slide under the battery and it slowly lifted out without applying heat.
mark - Yanıt
I'm having trouble with one screw not wanting to come out. Any suggestions to keep from stripping the head and getting it?
Patric - Yanıt
which screws are which sizes cause i ordered new ones and cant figure it out
MONsterHEIT - Yanıt
I also did not see the need to remove the display assembly for this repair. However I did place a can of corn against the vertically positioned display and then secured the display to the can with a rubber band.
whiteshephard - Yanıt
I recommend removing the display assembly, I didn’t and somehow damaged the home button cable. At least remove the cover to ease the tension on the cables.
Remove the front panel assembly cable bracket from the logic board.
  • Remove the front panel assembly cable bracket from the logic board.
Yorum Ekle
In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board. While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
  • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
  • While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
Why does the screen need to come off?
Sterling Coffey (N0SSC) - Yanıt
Because the cables are delicate, and following steps are easier if phone halves are not flopping around together, especially for amateurs.
Matthew Goheen - Yanıt
Disconnect the home button cable connector. Disconnect the home button cable connector.
  • Disconnect the home button cable connector.
Yorum Ekle
Make sure the battery is disconnected before you disconnect or reconnect the cable in this step. Use a plastic opening tool to disconnect the display data cable connector.
  • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
  • Use a plastic opening tool to disconnect the display data cable connector.
  • When reassembling your phone, the display data cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
The piece of advice about power cycling the phone by disconnecting and reconnecting the battery proved crucial to the success of my repair (camera and lens replacement). At first when charging the phone after closing it, I got a dark, blank screen with an intermittent buzzing noise. After re-opening the phone and making sure all cables had been properly reconnected, I ignored the advice to power cycle the phone. Still all I got was a dark, blank screen (and intermittent buzzing if charging t). Then I opened it a third time (leaving the screen connected and attached at a 90 degree angle) and I only disconnected and reconnected the battery. Voila! When I closed the phone and powered it up, I got the screen to light up!
Gianni - Yanıt
how did you disconnect and reconnect the battery?
Teresa Trevino - Yanıt
If you’ve been following the guide, you already disconnected it in this step. To reconnect it, just line up the connector and press it into place.
Jeff Suovanen -
Finally, disconnect the digitizer cable connector. When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  • Finally, disconnect the digitizer cable connector.
  • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
some images and guidance regarding reassembly would be helpful. You don't need to use the spudger to get them back on: fingers are better because there's a really subtle click you feel when you get them seated properly.
When you're reassembling, a note that this is the step where you should test for proper screen function would be really useful. First time I reassembled, I didn't seat something properly, got all the screws back together and then realized the screen wasn't functioning properly. Had to disassemble back down to step 14 and then re-reassemble.
I am having this issues right now! I have unplugged and plugged in these cables at least 20 times and each time I get white lines. I finally have it to where there are only 4 white lines and I am almost willing to live with it. Any suggestions?
mattmay002 -
Clean the screen connectors incase they are not making a clean connection
Karen Jones - Yanıt
I'm having nightmares with the digitizer connector. Simply can't get it to work unless I'm applying some pressure on the connectors. Everything seems almost microscopically clean. Any suggestions friends?
Henry A -
could it be the replacement screen? test with your old screen and see if you have the same problem.
ChiangFeng - Yanıt
To ++mattmay002++  Did you power cycle the phone? Check out the comments on the previous step for a how to.
Robert Liles - Yanıt
I had issues with it too. When connecting this cable, make sure to rock finger side to side after connecting. It’s a wide connector so try to listen for 2 clicks on this one connector. That’s how I fixed mine
Albert Einstein - Yanıt
Re-attaching this cable is the only tricky part to replacing the battery on my 6+. It had a bow on the middle that I had to flatten out before pressing the connector on with finger first on one edge and then on the other. I had white tire tracks on the screen and no touch screen until I connected it correctly. The front has to rest in just the right place on the back while attaching this thing so the cables aren’t strained the front doesn’t fall down. Small fingers would be a plus at this step.
richard - Yanıt
Remove the front panel assembly from the rear case.
  • Remove the front panel assembly from the rear case.
Never remove the screen without disconnecting the battery. It's possible the back light can be blown and that's a even more difficult repair. Always, ALWAYS, disconnect battery before repairing items. (Unless it's not possible.)
Marvin Ballard - Yanıt
How do you disconnect the battery from the screen?
Shamil Bhatti -
The Step 11 disconnects the battery :)
jeffxtechs - Yanıt
I think you mean Step 8 :)
Jeff Suovanen -
I tried it once and
Brian - Yanıt
And what? I tried it once and here’s a million dollars?
Oh I get it… they got him! :(
https://www.youtube.com/watch?v=UlznqpBg...
domarius -
When disassembling the iphone at this point note the cables, and there placement/orientation.
GERARD SZAREK - Yanıt
Remove the following Phillips screws securing the upper component bracket:
  • Remove the following Phillips screws securing the upper component bracket:
    • One 1.5 mm screw
    • Two 2.3 mm screws
Nice move, which can stop the bracket from falling down.quite detailed instruction. but you should choice an excellent front facing camera and sensor before the replacement.
William - Yanıt
Attempted this repair and my touch screen completely stopped working. Great walkthrough, but not sure what I did wrong in the repair to cause my issue.
surfincubus86 - Yanıt
Hi I've had exactly the same problem, what was your solution to this? would be very helpful!
Iona -
I had the same issue. My screen quit working and I could feel heat coming through my phone at the earpiece. I took the phone apart again and realized that the data cable for the screen had come loose. When I reattached the data cable and starting working steps 12-18 backwards to replace the shield, as noted in the very last step, I see that youhave to keep the screen at an inclinewhen replacing the shield over the cables. Otherwise, you stretch the display data cable and it can come loose. My screen works fine now and there is no heat coming from my earpiece.
Angela Hall -
Just completed this repair. My front facing microphone next to the ear piece had gone bad causing siri to not hear me and front facing videos had no sound. Definitely reccomend getting replacement parts from ifixit. Have had good experiences with all their parts unlike many other suppliers on the internet. Hate to admit it (don't want them to raise prices) but even though you pay a little bit more, you save frustration not getting DOA parts from cheaper sources. All of ifixit's parts are top quality and they even pack them in anti-static packaging. That says alot. Thanks ifixit!
sherwood7 - Yanıt
Great instructions save the later steps. The ear speaker piece having to bend 180 degrees for the installation needs more clarification.
howchewdoin - Yanıt
After this repair, my screen quit working and I could feel heat coming through my phone at the earpiece. I took the phone apart again and realized that the data cable for the screen had come loose. When I reattached the data cable and starting working steps 12-18 backwards to replace the shield, as noted in the very last step, I see that you have to keep the screen at an incline when replacing the shield over the cables. Otherwise, you stretch the display data cable and it can come loose. My screen works fine now and there is no heat coming from my earpiece.
Angela Hall - Yanıt
The middle screw, listed as a 2.3mm was actually a 2.9mm in my iPhone 6 Plus
Lift and remove the earpiece bracket from the display assembly.
  • Lift and remove the earpiece bracket from the display assembly.
Yorum Ekle
Use a the flat end of a spudger to pry up the front-facing camera and display cables, and gently push them aside.
  • Use a the flat end of a spudger to pry up the front-facing camera and display cables, and gently push them aside.
Yorum Ekle
Use a pair of tweezers to firmly grasp and remove the earpiece speaker from the display assembly.
  • Use a pair of tweezers to firmly grasp and remove the earpiece speaker from the display assembly.
Yorum Ekle
Use the tip of a spudger to gently pry up the sensor cable assembly from its recess in the display assembly. The cable is held in place with a mild adhesive.
  • Use the tip of a spudger to gently pry up the sensor cable assembly from its recess in the display assembly.
  • The cable is held in place with a mild adhesive.
Yorum Ekle
Pry the microphone portion of the front-facing camera and sensor cables from the display assembly. Pry the microphone portion of the front-facing camera and sensor cables from the display assembly.
  • Pry the microphone portion of the front-facing camera and sensor cables from the display assembly.
Yorum Ekle
Remove the front-facing camera and sensor cable assembly off the display assembly.
  • Remove the front-facing camera and sensor cable assembly off the display assembly.
Yorum Ekle
Remove the two 1.8 mm Phillips screws securing the home button bracket to the front panel.
  • Remove the two 1.8 mm Phillips screws securing the home button bracket to the front panel.
This guide is pointless, iPhone 6/6 plus home button is not replaceable, period.
Tom Chai - Yanıt
Yes it is absolutely replaceable. You need to remember it is a encrypted security feature, so you'll need the apple ID or password to regain control again if replaced. That's the whole point to secure your data.
Mike -
Yes, the iPhone 6 and 6 Plus home buttons are replaceable. I do several replacements for customers and they work just fine with one exception. The fingerprint reader around the home button does not work after replacing the home button
BrentTaylorBA - Yanıt
Hi Brent, I have a iPhone 6 plus with a shattered screen to repair and the home button is gone. You have said that you've been able to replace the home buttons successfully. I was wondering how you got past the error 53 problem when restoring it? Any suggestions or help would be greatly appreciated.
arcadian212 -
Sorry Arcadian212, There is no way to bypass Error 53 unless you install the original button, update to iOS 9, then put in the new button.
iRevive Mobile -
Error 53 was resolved by Apple with an iOS update, so fortunately this is no longer an issue! As others have stated, it's perfectly possible to replace the home button, but you will lose fingerprint sensor functionality (the original sensor is paired to your iPhone's logic board at the factory, and only Apple can pair a new one).
Jeff Suovanen -
Why does that make it pointless? The guide is geared towards screen replacement, with the intent of using the original home button and a new screen. It clearly states this. What about this guide is pointless? It's actually very helpful.
abyss478 - Yanıt
Warning: The iphone 6 will brick after a restore if the home button is replaced. I agree with the other commenters that it is not a replaceable part because of this issue. If you try to restore the iPhone 6 after replacing the home button it will get stuck in recovery mode and give error 53 when a restore is attempted. I learned this the hard way! Please be careful and don't restore your phone if you do this repair.
max - Yanıt
What did you do after your phone got stuck in recovery mode ?
Lynn -
this help me a lot, i got Replacement Home Button Rubber Gasket for iPhone 6 from http://www.laimarket.com/home-button-rub..., and don't know how to raplace
Kevin - Yanıt
I had an error 53 when trying to restore a iphone 6 plus.
I bought a new heat shield with flex ribbon attached and installing that allowed me to get a restore complete.
steve - Yanıt
I couldn't get my fingerprint reader to work after following this guide. I ended up taking the phone back apart and replacing the new screens' backing plate and the attached home button cable with the old, original one and now the fingerprint sensor works!
fsharp320 - Yanıt
The little square rubber gaskets that cloak the mounting holes (little square nubs at the bottom of the picture in Step 19) for the Pentalobe Screws in Step 1 above had a tendency to fall off the screen. Further, if replacing the screen, these should also accompany the other items transferred to the new screen. This is just a small oversight I have seen from this repair guide, otherwise, smooth as silk.
Justin - Yanıt
The connector seemed a bit raised after re-assembling, I noticed after pressing the bracket down on in preparation for screwing in. I don’t know if it’s normal for it to have a slightly raised feeling but it was noticeable. Enough to make me wonder if it’s too much pressure on it once it’s screwed together.
domarius - Yanıt
Remove the home button bracket from the front panel assembly.
  • Remove the home button bracket from the front panel assembly.
buen día, cuando no me reconoce el touch id pero el boton si hace la función de botón ejemplo si me envía a home pero no reconoce el alcance fácil dos toques no reconoce el lector biométrico
Yamir Maximino - Yanıt
Use the tip of a spudger to disconnect the home button connector from its socket on the home button cable. Use the tip of a spudger to disconnect the home button connector from its socket on the home button cable.
  • Use the tip of a spudger to disconnect the home button connector from its socket on the home button cable.
Will disabling and removing fingerprint passcode thru settings software wise prior to repair or starting the replacement, will this feature with a new replacement home button resolve the error 53 or the repairer need to use the original home button sensor with the correct fingerprint stored in the tiny small chip ? I have replaced a gsm iPhone 6S not plus screen making sure that not to tear off the sensor chip successfully repaired. -Joan
JOAN E. VERGARA - Yanıt
Hi Joan! If I am understanding your question correctly, disabling the fingerprint passcode prior to repair WILL NOT result in Touch ID working after the repair. You should look at Jeff Suovanen's comment at the bottom, as he explains the two ways to keep Touch ID working. In order to keep Touch ID working, you will need to find a logic board that is paired with the home button and replace both of those components.
Scott Havard -
  • Carefully wedge the tip of a spudger underneath the home button connector cable.
  • Gently move the spudger across to separate the home button connector cable from the adhesive securing it to the front panel assembly.
  • If the cable doesn't separate easily, apply heat using an iOpener or hair dryer to soften the adhesive, and try again. Be careful not to damage the cable.
Es necesario calentar para que se desprenda de una forma comoda
i found using a needle works well too, as the fine point of the needle will be able to get under the adhesive and i can gently separate it.
ChiangFeng - Yanıt
heat thoroughly with a hair dryer. (away from your work area so you don't blast your parts all over the place!) pops right off.
edwardlyman - Yanıt
Using your fingertip, gently push, but do not remove, the home button up from the opposite side to free one edge of the home button gasket from the front panel. Do not push the home button all the way through—you only need to get a corner free, so that you can pry it free with a spudger.
  • Using your fingertip, gently push, but do not remove, the home button up from the opposite side to free one edge of the home button gasket from the front panel.
  • Do not push the home button all the way through—you only need to get a corner free, so that you can pry it free with a spudger.
  • The rubber gasket surrounding the home button is very thin. To prevent the gasket from tearing, we recommend applying a minimal amount of heat.
Yorum Ekle
Carefully run the tip of a spudger underneath the perimeter of the home button to separate it from the front panel assembly. Carefully run the tip of a spudger underneath the perimeter of the home button to separate it from the front panel assembly.
  • Carefully run the tip of a spudger underneath the perimeter of the home button to separate it from the front panel assembly.
The little rubber gasket seems to be a moisture seal. It isn’t glued down but over time it seals itself to the display. Pushing the spudger around underneath simply breaks the bond between the two surfaces. Be sure to do it carefully so as not to tear it.
bichmgnt - Yanıt
Lift and remove the home button assembly off the front panel assembly.
  • Lift and remove the home button assembly off the front panel assembly.
So this fix is hardware only? Do I need to disable the touch ID feature before removal and wWhat do I do next to get the touch ID feature to function?
Dasteufelhund - Yanıt
Remove the two 1.7 mm Phillips screws (one on top and one on bottom) securing the LCD shield plate to the display assembly. Remove the two 1.7 mm Phillips screws (one on top and one on bottom) securing the LCD shield plate to the display assembly.
  • Remove the two 1.7 mm Phillips screws (one on top and one on bottom) securing the LCD shield plate to the display assembly.
Yorum Ekle
Remove three 1.3 mm Phillips screws from each side of the LCD shield plate (six total). Remove three 1.3 mm Phillips screws from each side of the LCD shield plate (six total).
  • Remove three 1.3 mm Phillips screws from each side of the LCD shield plate (six total).
The required tools list specifies a phillips #000 screwdriver, but this section indicates #00 sized screws. Can some confirm for me the actual size of the screws? If they are #00, I see the screwdrivers for this size come in 1.5 mm and 2.5 mm versions. Which should I get?
Sidney Burton - Yanıt
If you’re using iFixit bits, either the #000 or the #00 will work fine here. Bit sizes are not standardized across manufacturers, so if you’re using tools from another vendor you’ll just have to test as you go.
Jeff Suovanen -
The next step requires peeling one end of the home button cable (highlighted in red in the second picture) that is affixed to the back of the display assembly with strong adhesive. We highly recommend using an iOpener to heat the bottom of the display assembly, directly on top of the home button. The next step requires peeling one end of the home button cable (highlighted in red in the second picture) that is affixed to the back of the display assembly with strong adhesive. We highly recommend using an iOpener to heat the bottom of the display assembly, directly on top of the home button.
  • The next step requires peeling one end of the home button cable (highlighted in red in the second picture) that is affixed to the back of the display assembly with strong adhesive. We highly recommend using an iOpener to heat the bottom of the display assembly, directly on top of the home button.
you can remove this by using the smallest flat screw driver bit you have. Using the supplied picture as reference start at the lower left hand corner and push gently between the connector ribbon and the case. The glue easily separated for me.
Do not peel off the ribbon cable!
You should take off small rectangular metal plate on which connector is. The glue is between the metal and plastic body.
Use a sharp needle at the lower left corner.
peoplewide - Yanıt
Carefully lift—but do not remove—the  LCD shield plate by lifting the end nearest the earpiece speaker a few millimeters from the display assembly. Gently lift the other end (nearest the home button) to peel the home button cable off the display assembly. Be extremely cautious as you peel the home button cable. It is a fragile cable. If you feel more than slight resistance, we recommend reheating and reusing the iOpener to soften the adhesive.
  • Carefully lift—but do not remove—the LCD shield plate by lifting the end nearest the earpiece speaker a few millimeters from the display assembly.
  • Gently lift the other end (nearest the home button) to peel the home button cable off the display assembly.
  • Be extremely cautious as you peel the home button cable. It is a fragile cable. If you feel more than slight resistance, we recommend reheating and reusing the iOpener to soften the adhesive.
  • Remove the LCD shield plate off the display assembly.
  • Display assembly remains.
Yorum Ekle
Sonuç
167 başka kişi bu kılavuzu tamamladı.
7 Yorum
I know this is a old guide but i have a question. My iphone was screen broken and i change it with a original complete iphone screen, the home button works fine but the touch id dont work. I change the home button to the one that i have in the broken screen and still the touch id dont work. What can i do to fix the touch id?
Juanjo Checo - Yanıt
Help! The home button cable attached to the metal front panel ripped a little as I was gently using my fingers to lift it off the screen. Now the home button doesn't work. Did I ruin the phone or is it possible to get a front panel?
Merry Hansen - Yanıt
I recently purchased this iFixit kit for my iPhone 6 Plus replacement of my screen that was cracked. I followed the instructions above, and my phone won't turn on. There is a part in to the right of the battery, just below the screen connections, that is really hot. After I noticed it wouldn't turn on, even after plugging it in, I took it back apart, and reseated the connections again. It still doesn't work. I will not purchase this kit again.
Dustin Klumb - Yanıt
Bought this recently and I must say that I'm a little bit disappointed:
- the screen doesn't fit as before, you can feel a rough edge - I tried 4 times to put it correctly watching many video tutorials and I had the same result so I assume it's because it's not an original screen
- the colours are not the same anymore, looks like the saturation is on a lower setting - can't see the bright colours anymore
Overall I would rate this part 6 out of 10.
andrewbuta - Yanıt
Followed this guide to the letter about 1 week ago. Happy to say its very accurate and my iphone is working 100%
Most difficult and time consuming part was re-inserting the front-facing camera and sensor cable assembly (Step 25) and also removing the home button cable (step 36)
morjo21 - Yanıt
I’ve just completed this guide successfully using replacement parts I’ve ordered with ifixit in Europe. To my own surprise, everything is working: both cameras, home button, fingerprint scanner and id. Just great. I didn’t have the iSclack tool so I just used the suction cup. Also, I had to use a hair dryer instead of the iOpener tool, and it worked great even with the home button cable, just go gentle and give the heat some time to soften up the adhesive. Thanks for the great guide.
Georg Federmann - Yanıt
Is this for if it don’t light up? because mine won’t come on.
Hunter Rowland - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 52
Son 7 Gün: 404
Son 30 Gün: 1,801
Her zaman: 130,885
