Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Use this guide to replace the power button cable.
  1. Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
    • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 6 Plus that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip down two steps.
    • If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus.
    • Close the handle on the iSclack, opening the suction cup jaws.
    • Place the bottom of your iPhone in between the suction cups.
    • Position the iSclack's upper suction cup against the display, near the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
    • If your display or back glass is badly cracked, covering it with a layer of clear packing tape may help the suction cups adhere. The iSclack also includes two pieces of tape for this purpose.
  2. Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case. The iSclack is designed to safely open your iPhone enough to separate the pieces, but not enough to damage any of the display cables.
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone enough to separate the pieces, but not enough to damage any of the display cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on to Step 7.
  3. If you don't have an iSclack, use a single suction cup to lift the front panel:
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  5. Pull the plastic nub to release the vacuum seal on the suction cup. Remove the suction cup from the display assembly.
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  6. Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge. Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone. Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  7. Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book. During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
    • Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  8. Remove the following Phillips screws from the battery connector bracket:
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.3 mm screw
    • One 3.1 mm screw
  9. Remove the metal battery connector bracket from the iPhone.
    • Remove the metal battery connector bracket from the iPhone.
  10. Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
    • Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  11. Remove the following Phillips screws securing the front panel assembly cable bracket:
    • Remove the following Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.5 mm screw
    • One 2.9 mm screw
    • Do not attempt to insert longer screws into the red marked screw holes. Doing so may result in irreparable damage to the logic board.
  12. Remove the front panel assembly cable bracket from the logic board.
    • Remove the front panel assembly cable bracket from the logic board.
  13. In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board. While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
  14. Disconnect the home button cable connector. Disconnect the home button cable connector.
    • Disconnect the home button cable connector.
  15. Make sure the battery is disconnected before you disconnect or reconnect the cable in this step. Use a plastic opening tool to disconnect the display data cable connector.
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a plastic opening tool to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  16. Finally, disconnect the digitizer cable connector. When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
    • Finally, disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  17. Remove the front panel assembly from the rear case.
    • Remove the front panel assembly from the rear case.
  18. Peel back the first battery adhesive tab from the bottom right edge of the battery.
    • Peel back the first battery adhesive tab from the bottom right edge of the battery.
    • Use your fingers or blunt tweezers. Be extra careful when working near the battery; puncturing a lithium-ion battery can release dangerous chemicals and cause a fire.
  19. Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly. Very slowly, pull and stretch one adhesive strip away from the battery, toward the bottom of the iPhone.
    • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
    • Very slowly, pull and stretch one adhesive strip away from the battery, toward the bottom of the iPhone.
    • Allow the strip to stretch out before pulling any harder. If you can't feel it stretching, ease up, or it will break.
    • Pull at as low of an angle as you can without snagging the adhesive strip on any of the components along the lower edge of the phone.
    • Don't press down on the battery as you pull the strip.
    • The strip will stretch to many times its original length. Continue pulling slowly until it releases and slips out from underneath the battery.
    • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
    • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strips, and then proceed as instructed below.
  20. Peel back the second battery adhesive tab from the other side of the battery. Again, pull and slowly stretch the adhesive tab to slide it out from between the battery and the rear case.
    • Peel back the second battery adhesive tab from the other side of the battery.
    • Again, pull and slowly stretch the adhesive tab to slide it out from between the battery and the rear case.
    • Continue pulling the adhesive tab until it releases completely from the battery. If it breaks, try to retrieve the remaining length and continue pulling, or proceed as instructed below.
  21. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  22. Peel back the final battery adhesive tab from the bottom edge of the battery. Gently pull the battery adhesive tab upward and away from the battery, allowing the adhesive strip to slowly slide out from between the battery and the rear case. Place one hand over the battery as the final strip comes out, or it may fling the battery out of the iPhone.
    • Peel back the final battery adhesive tab from the bottom edge of the battery.
    • Gently pull the battery adhesive tab upward and away from the battery, allowing the adhesive strip to slowly slide out from between the battery and the rear case.
    • Place one hand over the battery as the final strip comes out, or it may fling the battery out of the iPhone.
    • Continue pulling until the final strip comes free from the iPhone.
    • If you removed all three adhesive strips successfully, skip over the next two steps.
    • If any of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
  23. If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
    • If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
  24. Flip the iPhone back over and insert a plastic card between the left side of the battery and the rear case.
    • Flip the iPhone back over and insert a plastic card between the left side of the battery and the rear case.
    • Don't pry under the topmost section of the battery, near the volume up button and mute switch, or you may damage the audio controls cable, which is adhered to the rear case just beneath the battery.
    • Do not pry against the logic board, or you may permanently damage your iPhone.
    • Be careful to keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
    • Press the card in farther to break up the adhesive behind the battery.
    • Alternatively, a piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set.
    • Thread the floss or string underneath one end of the battery and pull side to side in a sawing motion to separate the adhesive.
  25. Remove the battery from the iPhone.
    • Remove the battery from the iPhone.
    • If your replacement battery came in a plastic sleeve, remove the sleeve before installation by pulling it away from the the ribbon cable.
    • If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
  26. Remove the following screws securing the rear-facing camera bracket to the rear case:
    • Remove the following screws securing the rear-facing camera bracket to the rear case:
    • One 1.7 mm Phillips #00 screw
    • One 2.3 mm Phillips #00 screw
  27. Lift and remove the rear-facing camera bracket out of the iPhone.
    • Lift and remove the rear-facing camera bracket out of the iPhone.
  28. Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the logic board.
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the logic board.
  29. Carefully lift and remove the rear-facing camera out of the iPhone.
    • Carefully lift and remove the rear-facing camera out of the iPhone.
  30. Remove the following screws securing the antenna bracket to the rear case:
    • Remove the following screws securing the antenna bracket to the rear case:
    • One 1.5 mm Phillips #00 screw
    • One 2.8 mm Phillips #00 screw
  31. Grasp the antenna bracket with a pair of tweezers and lift it off the iPhone.
    • Grasp the antenna bracket with a pair of tweezers and lift it off the iPhone.
  32. Carefully pry the antenna connector up off the logic board with a plastic opening tool.
    • Carefully pry the antenna connector up off the logic board with a plastic opening tool.
  33. Grasp the antenna connector with a pair of tweezers and gently lift it from its retaining clip on the logic board. Grasp the antenna connector with a pair of tweezers and gently lift it from its retaining clip on the logic board.
    • Grasp the antenna connector with a pair of tweezers and gently lift it from its retaining clip on the logic board.
  34. The two connectors may be coupled by a single adhesive tab. If this is the case, then they may detach as a pair. Disconnect the power button cable and audio control cable connectors from their respective sockets on the logic board.
    • The two connectors may be coupled by a single adhesive tab. If this is the case, then they may detach as a pair.
    • Disconnect the power button cable and audio control cable connectors from their respective sockets on the logic board.
  35. Remove the following screws securing the top cellular antenna to the rear case:
    • Remove the following screws securing the top cellular antenna to the rear case:
    • Two 1.6 mm Phillips #00 screws
  36. Use a pair of tweezers to grasp and remove the top cellular antenna out of the iPhone. During reassembly, make sure to place the small washer in the top left corner of the antenna assembly.
    • Use a pair of tweezers to grasp and remove the top cellular antenna out of the iPhone.
    • During reassembly, make sure to place the small washer in the top left corner of the antenna assembly.
  37. Pry the vibrator connector cable up from its socket on the logic board with the flat end of a spudger.
    • Pry the vibrator connector cable up from its socket on the logic board with the flat end of a spudger.
  38. Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board. Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board.
    • Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board.
  39. Grasp the interconnect antenna cable with a pair of tweezers and carefully deroute it from its channel on the speaker assembly. Grasp the interconnect antenna cable with a pair of tweezers and carefully deroute it from its channel on the speaker assembly.
    • Grasp the interconnect antenna cable with a pair of tweezers and carefully deroute it from its channel on the speaker assembly.
  40. Remove the two 2.5 mm Phillips #00 screws securing the vibrator to the rear case.
    • Remove the two 2.5 mm Phillips #00 screws securing the vibrator to the rear case.
  41. Lift and remove the vibrator out of the iPhone.
    • Lift and remove the vibrator out of the iPhone.
  42. Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray. Press to eject the tray.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force.
  43. Remove the SIM Card tray assembly from the iPhone.
    • Remove the SIM Card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  44. Remove the single 2.8 mm Phillips #00 screw securing the plastic clip to the logic board.
    • Remove the single 2.8 mm Phillips #00 screw securing the plastic clip to the logic board.
  45. Remove the single 1.3 mm Phillips #00 screw recessed against the top of the rear case.
    • Remove the single 1.3 mm Phillips #00 screw recessed against the top of the rear case.
  46. Use a pair of tweezers to firmly grasp the plastic clip and remove it from the iPhone.
    • Use a pair of tweezers to firmly grasp the plastic clip and remove it from the iPhone.
  47. Remove the single 1.6 mm Phillips #00 screw securing the antenna clip to the rear case.
    • Remove the single 1.6 mm Phillips #00 screw securing the antenna clip to the rear case.
  48. Carefully grasp the antenna clip with a pair of tweezers and remove it from the iPhone.
    • Carefully grasp the antenna clip with a pair of tweezers and remove it from the iPhone.
  49. Remove the following screws securing the logic board to the rear case:
    • Remove the following screws securing the logic board to the rear case:
    • Two 2.4 mm standoff screws
    • Standoff screws are best removed using an iPhone Standoff Screwdriver Bit and driver handle.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • One 2.1 mm Phillips #00 screw
  50. Carefully raise—but do not remove—the logic board, lifting it from the bottom edge nearest the Lightning connector.
    • Carefully raise—but do not remove—the logic board, lifting it from the bottom edge nearest the Lightning connector.
  51. Do not remove the logic board. At this point it is still tethered to the rear case via an antenna connector.
    • Do not remove the logic board. At this point it is still tethered to the rear case via an antenna connector.
    • Continue carefully lifting the bottom side of the logic board until it is vertical.
  52. Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone. Use the flat end of a spudger to disconnect the antenna connector from its socket on the back of the logic board.
    • Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone.
    • Use the flat end of a spudger to disconnect the antenna connector from its socket on the back of the logic board.
  53. Lift and remove the logic board out of the iPhone.
    • Lift and remove the logic board out of the iPhone.
  54. Use a pair of tweezers to peel the single adhesive tab that resides on top of both the power button and audio control/rocker switch cable connectors. Use a pair of tweezers to peel the single adhesive tab that resides on top of both the power button and audio control/rocker switch cable connectors.
    • Use a pair of tweezers to peel the single adhesive tab that resides on top of both the power button and audio control/rocker switch cable connectors.
  55. Remove the single 1.3 mm Phillips #00 screw securing the power button cable bracket to the rear case.
    • Remove the single 1.3 mm Phillips #00 screw securing the power button cable bracket to the rear case.
  56. Carefully grasp the bracket with a pair of tweezers and remove it from the iPhone.
    • Carefully grasp the bracket with a pair of tweezers and remove it from the iPhone.
  57. Remove the following screws securing the power button cable bracket to the inner edge of the rear case:
    • Remove the following screws securing the power button cable bracket to the inner edge of the rear case:
  58. Grasp the power button cable bracket with a pair of tweezers and remove it from the iPhone.
    • Grasp the power button cable bracket with a pair of tweezers and remove it from the iPhone.
  59. Remove the single 2.1 mm Phillips #00 screw securing the power button switch to the rear case.
    • Remove the single 2.1 mm Phillips #00 screw securing the power button switch to the rear case.
  60. Pull the power button switch out of its recess on the rear case with a pair of tweezers, and begin carefully peeling the power button cable from the rear case.
    • Pull the power button switch out of its recess on the rear case with a pair of tweezers, and begin carefully peeling the power button cable from the rear case.
  61. Continue gently peeling the power button cable off the rear case and remove it from the iPhone. Continue gently peeling the power button cable off the rear case and remove it from the iPhone. Continue gently peeling the power button cable off the rear case and remove it from the iPhone.
    • Continue gently peeling the power button cable off the rear case and remove it from the iPhone.
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
5 Yorum
I just did this while thing and my lock button still doesn’t work… any other suggestions?
Zachary Castle - Yanıt
Just finished the replacement. Went fine except the replacement part was just a bit different (from iFixit). The power button replacement cable was about 1-2mm shorter than the original so it was tough trying to make it work. I took photos, but not sure where I can upload them.
Mkopro97 - Yanıt
Step 53: “raise—but do not remove—the logic board” did not mention that there was adhesive towards the top holding the board to the inner case. I had to use a thin plastic card to slide between to release the bond.
Paul Jackson - Yanıt
I did it with minor problems :
1 Quite difficult to stick the power button cable. On the left it must be just in front of the connector. On the right, at the exact place. Idem on the top for the light. And it is very sticky.
2 After doing the all work, half of the screen didn’t respond to the orders. But after cleaning it’s 4 connectors. Everything was OK.
P.M.
patrick - Yanıt
i like how this is moderate but the volume buttons which had 20 steps less and were the exact same procedure are very difficult
Nico Kotik - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 25
Son 30 gün: 108
Her zaman: 14,991
