Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
iPhone 6 Plus iSclack Opening Procedure
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. iPhone 6 Plus iSclack Opening Procedure, iSclack Opening Procedure: adım 1, 3 resimden 1. iPhone 6 Plus iSclack Opening Procedure, iSclack Opening Procedure: adım 1, 3 resimden 2. iPhone 6 Plus iSclack Opening Procedure, iSclack Opening Procedure: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    iSclack
    $24.99
    Satın Al
    • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 6 Plus that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip down two steps.
    • If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus.
    • Close the handle on the iSclack, opening the suction cup jaws.
    • Place the bottom of your iPhone in between the suction cups.
    • Position the iSclack's upper suction cup against the display, near the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
  2. iPhone 6 Plus iSclack Opening Procedure: adım 2, 2 resimden 1. iPhone 6 Plus iSclack Opening Procedure: adım 2, 2 resimden 2.
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone enough to separate the pieces, but not enough to damage any of the display cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on to Step 7.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 608
