Giriş
Follow the steps in this guide to replace the upper left antenna in an iPhone 6s.
Neye ihtiyacın var
Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
Bu adımda kullanılan alet:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Remove two Phillips screws securing the battery connector bracket, of the following lengths:
One 2.9 mm screw
One 2.2 mm screw
Remove the following four Phillips screws securing the display cable bracket:
Three 1.2 mm screws
One 2.8 mm screw
Remove the two 2.3 mm Phillips screws over the audio control cable bracket.
Remove the audio control cable bracket.
52 farklı kişi bu kılavuzu tamamladı.
10 Yorum
Hi Evan, could you clarify if this is a WiFi antenna or cellular antenna? In the Step 31 of some other 6S guides e.g. iPhone 6s Upper Component Cable Replacement, iPhone 6s Power Button Cover Replacement, you have described it as WiFi antenna. Thanks in advance for your clarification.
Bei Schritt 23 wurde vergessen, 2 1,5 mm Schrauben vor Kopf in y+ zu entfernen - siehe Bild
Those screws are in the second photo of step 23.
