Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
Bu adımda kullanılan alet:Anti-Clamp$24.95-
If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Apply a suction cup to the lower left corner of the display assembly.
Take care not to place the suction cup over the home button.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case.
Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
Remove the spudger and reinsert it on the bottom edge, where you pried the phone open.
Slide the spudger to the right, along the bottom edge of the phone.
Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
Use the suction cup to open the display, breaking the last of the adhesive.
Pull up on the nub on the top side of the suction cup to remove it from the front panel.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95-
Remove two Phillips screws securing the battery connector bracket, of the following lengths:
One 2.9 mm screw
One 2.2 mm screw
Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
Remove the following four Phillips screws securing the display cable bracket:
Three 1.2 mm screws
One 2.8 mm screw
Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
Disconnect the digitizer cable by prying it straight up from its socket on the logic board.
Disconnect the display cable by prying it straight up from its socket on the logic board.
18 farklı kişi bu kılavuzu tamamladı.
