Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
39 farklı kişi bu kılavuzu tamamladı.
2 Yorum
I noticed both my pentalobe screws wouldn’t screw in last time. Upon checking the little components that the screws fix into were loose inside. Not a major drama but they also seem to hold the charger cable in place… or at least I’ve noticed cables are loose on my iPhone 6 since then. Is there a part I can buy to fix this issue, does anyone know please?
I have an iPhone 6s plus, but I got a new phone recently so I put my 6s plus in my side table and went back to it a couple of weeks later just to see that the pentalobe screws are missing and the phone will no longer charge, I also realized that when I plug the charger in its a bit loose. There was also nothing wrong with the phone before it worked perfectly fine.
