Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Prerequisite guide for replacing the display assembly in your iPhone 6s Plus.
Note: This is not a complete replacement guide. To replace a broken or cracked screen on an iPhone 6s, head over to this guide: iPhone 6s Plus Screen Replacement
Neye ihtiyacın var
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
Bu adımda kullanılan alet:Anti-Clamp$24.95
If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
One 2.9 mm screw
One 2.3 mm screw
Remove the following Phillips screws:
Three 1.3 mm screws
One 1.6 mm screw
One 3.0 mm screw
17 farklı kişi bu kılavuzu tamamladı.
3 Yorum
The most comprehensive and useful instructions I took the time to find. The screw placement annotations are very informative and handy. Well done. It helped me to flawlessly complete replacement of my screen and digitizer.
I did everything step by step. After completing it all and putting the phone back together and turning it back on I noticed that the auto-brightness function doesn't work anymore.
