Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Follow the steps in this guide to replace the earpiece speaker in your iPhone 6s Plus.
You can also use this guide to replace the earpiece speaker bracket.
Neye ihtiyacın var
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
Bu adımda kullanılan alet:Anti-Clamp$24.95
If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
One 2.9 mm screw
One 2.3 mm screw
Remove the following Phillips screws:
Three 1.3 mm screws
One 1.6 mm screw
One 3.0 mm screw
Remove the following three Phillips screws:
Two 2.7 mm screws
One 1.4 mm screw
89 farklı kişi bu kılavuzu tamamladı.
12 Yorum
For future reference, I found only a slight physical difference between the two. Tested both out on a 6s Plus and they both seem to work exactly the same.
Awsome done it
Guide worked well. Fixed my 6s Plus with no issues.
Thanks.
Is the earpiece bracket the same as the one in the iphone 6s?
