Giriş
Use this guide to replace the loudspeaker in an iPhone 6s.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, next to the Lightning connector.
Optionally, apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove two Phillips screws securing the battery connector bracket, of the following lengths:
One 2.9 mm screw
One 2.2 mm screw
Remove the following four Phillips screws securing the display cable bracket:
Three 1.2 mm screws
One 2.8 mm screw
Use the point of a spudger to lift and disconnect the antenna cable from the bottom end of the logic board.
Remove the tape covering the antenna cable on the edge of the speaker.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our iPhone 6s Answers community for troubleshooting help.
55 farklı kişi bu kılavuzu tamamladı.
10 Yorum
Skip steps 16 to 34. Those steps are unnecessary and are added work. Make sure you prop up the front display securely.
The steps as posted in this guide are far too cumbersome. This fix is super easy.. here you go
1) Complete Steps 1-15 as shown
2) Scroll all.... the way down
3) Pick it back up at step 34-53 **before putting your new speaker back in, just give the ports a cleaning with a toothpick or the tweezers provided by iFixit.
Total time was maybe 30 mins.. It's easy no worries
Is iPhone 6 Speaker compatible with an iPhone 6S?
