Ana içeriğe geç
iPhone 7 Display Assembly Replacement
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. iPhone 7 Display Assembly Replacement, Display Assembly: adım 1, 3 resimden 1. iPhone 7 Display Assembly Replacement, Display Assembly: adım 1, 3 resimden 2. iPhone 7 Display Assembly Replacement, Display Assembly: adım 1, 3 resimden 3.
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  2. iPhone 7 Display Assembly Replacement: adım 2, 3 resimden 1. iPhone 7 Display Assembly Replacement: adım 2, 3 resimden 2. iPhone 7 Display Assembly Replacement: adım 2, 3 resimden 3.
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
  3. iPhone 7 Display Assembly Replacement: adım 3, 2 resimden 1. iPhone 7 Display Assembly Replacement: adım 3, 2 resimden 2.
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  4. iPhone 7 Display Assembly Replacement: adım 4, 1 resimden 1.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Evan Noronha
228.333 İtibar
168 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 18
Her zaman: 2,815
