Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace the large antenna component located in the top corner of your iPhone 7 Plus, opposite the rear-facing camera.
Neye ihtiyacın var
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Insert the flat end of the spudger between the front panel and the rear case at the lower left edge of the iPhone.
Slide the spudger up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
Three 1.2 mm screws
One 2.6 mm screw
Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
Remove three Phillips screws securing the antenna component:
Two 1.3 mm screws
One 1.2 mm screw
22 farklı kişi bu kılavuzu tamamladı.
5 Yorum
thank you so much…
my phone has not been saying no service and when i opened it up this piece was missing. Is this piece missing causing me to not get service?
great guide, works for the regular 7 too
Very precise ,thank you Paige
Tony 8/11/20
This is only the antenna cover. Why is it sold and labeled as top left antenna ?
