Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
iPhone 7 Rear Case Replacement
Neye ihtiyacın var
  1. iPhone 7 Rear Case Replacement, Pentalobe Screws: adım 1, 1 resimden 1.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Rear Case Replacement, iPhone 7 Opening Procedure: adım 2, 1 resimden 1.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. iPhone 7 Rear Case Replacement: adım 3, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 3, 2 resimden 2.
    • Attach a suction cup to the lower half of the display assembly, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 7 Rear Case Replacement: adım 4, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 4, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 4, 3 resimden 3.
    • Pull up on the suction cup to create a small gap between the display assembly and the rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong, and creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
  5. iPhone 7 Rear Case Replacement: adım 5, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 5, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 5, 3 resimden 3.
    • Slide the spudger to the left along the lower edge of the iPhone.
    • Twist the spudger to widen the gap between the display and rear case.
  6. iPhone 7 Rear Case Replacement: adım 6, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 6, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 6, 3 resimden 3.
    • Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch.
    • Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display.
  7. iPhone 7 Rear Case Replacement: adım 7, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 7, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 7, 3 resimden 3.
    • Insert the flat edge of a spudger into the bottom right corner of the device.
    • Twist the spudger to widen the gap between the display assembly and the rear case.
    • Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
    • Do not insert the spudger further than the adhesive to avoid damaging delicate ribbon cables along the right edge.
  8. iPhone 7 Rear Case Replacement: adım 8, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 8, 2 resimden 2.
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are ribbon cables along the right edge of the device connecting the display to the logic board.
  9. iPhone 7 Rear Case Replacement: adım 9, 1 resimden 1.
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  10. iPhone 7 Rear Case Replacement: adım 10, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 10, 2 resimden 2.
    • Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place.
    • Be careful not to damage the plastic clips on the top edge of the phone.
  11. iPhone 7 Rear Case Replacement: adım 11, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 11, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 11, 3 resimden 3.
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  12. iPhone 7 Rear Case Replacement, Battery Disconnection: adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    Tri-point Y000 Screwdriver
    $5.99
    Satın Al
  13. iPhone 7 Rear Case Replacement: adım 13, 1 resimden 1.
    • Remove the lower connector bracket.
  14. iPhone 7 Rear Case Replacement: adım 14, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 14, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 14, 3 resimden 3.
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  15. iPhone 7 Rear Case Replacement, Display Assembly: adım 15, 3 resimden 1. iPhone 7 Rear Case Replacement, Display Assembly: adım 15, 3 resimden 2. iPhone 7 Rear Case Replacement, Display Assembly: adım 15, 3 resimden 3.
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  16. iPhone 7 Rear Case Replacement: adım 16, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 16, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 16, 3 resimden 3.
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
  17. iPhone 7 Rear Case Replacement: adım 17, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 17, 2 resimden 2.
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  18. iPhone 7 Rear Case Replacement: adım 18, 1 resimden 1.
  19. iPhone 7 Rear Case Replacement, Barometric Vent: adım 19, 1 resimden 1.
    • Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
  20. iPhone 7 Rear Case Replacement: adım 20, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 20, 2 resimden 2.
    • Remove the vent.
  21. iPhone 7 Rear Case Replacement, Taptic Engine: adım 21, 2 resimden 1. iPhone 7 Rear Case Replacement, Taptic Engine: adım 21, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
  22. iPhone 7 Rear Case Replacement: adım 22, 1 resimden 1.
    • Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
  23. iPhone 7 Rear Case Replacement: adım 23, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 23, 2 resimden 2.
    • Remove the Taptic Engine.
  24. iPhone 7 Rear Case Replacement, Speaker Assembly: adım 24, 1 resimden 1.
    • Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
    • One 3.2 mm screw
  25. iPhone 7 Rear Case Replacement: adım 25, 1 resimden 1.
    • Remove the following three Phillips screws securing the speaker to the rear case:
    • Two 1.3 mm screws
    • One 2.0 mm screw
  26. iPhone 7 Rear Case Replacement: adım 26, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 26, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 26, 3 resimden 3.
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
  27. iPhone 7 Rear Case Replacement: adım 27, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 27, 2 resimden 2.
    • Use tweezers to derout the antenna cables from their bracket on the logic board.
  28. iPhone 7 Rear Case Replacement: adım 28, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 28, 2 resimden 2.
    • Use tweezers to remove the antenna cables from the clip on the speaker.
    • Make sure to grasp the cable near the clip in order to avoid damaging the cable.
  29. iPhone 7 Rear Case Replacement: adım 29, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 29, 2 resimden 2.
    • Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
  30. iPhone 7 Rear Case Replacement: adım 30, 1 resimden 1.
    • Remove the speaker.
  31. iPhone 7 Rear Case Replacement, SIM Card: adım 31, 3 resimden 1. iPhone 7 Rear Case Replacement, SIM Card: adım 31, 3 resimden 2. iPhone 7 Rear Case Replacement, SIM Card: adım 31, 3 resimden 3.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
    • Remove the SIM card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  32. iPhone 7 Rear Case Replacement, Logic Board Connectors: adım 32, 2 resimden 1. iPhone 7 Rear Case Replacement, Logic Board Connectors: adım 32, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the rear-facing camera connector.
  33. iPhone 7 Rear Case Replacement: adım 33, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 33, 2 resimden 2.
    • Remove the following Phillips screws securing the rear camera bracket to the rear case:
    • One 1.3 mm screw
    • One 2.5 mm screw
  34. iPhone 7 Rear Case Replacement: adım 34, 1 resimden 1.
    • Remove the bracket.
  35. iPhone 7 Rear Case Replacement: adım 35, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 35, 2 resimden 2.
    • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
  36. iPhone 7 Rear Case Replacement: adım 36, 1 resimden 1.
    • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
  37. iPhone 7 Rear Case Replacement: adım 37, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 37, 2 resimden 2.
    • Remove the upper cable bracket.
  38. iPhone 7 Rear Case Replacement: adım 38, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 38, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the upper cable connector.
  39. iPhone 7 Rear Case Replacement: adım 39, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 39, 2 resimden 2.
    • Remove the four Phillips screws securing the Wi-Fi antenna:
    • Three 1.2 mm screws
    • One 1.7 mm screw
  40. iPhone 7 Rear Case Replacement: adım 40, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 40, 2 resimden 2.
    • Remove the top left antenna.
  41. iPhone 7 Rear Case Replacement: adım 41, 1 resimden 1.
    • Remove the following Phillips screws:
    • One 1.3 mm screw
    • One 2.2 mm screw
  42. iPhone 7 Rear Case Replacement: adım 42, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 42, 2 resimden 2.
  43. iPhone 7 Rear Case Replacement: adım 43, 1 resimden 1.
    Standoff Screwdriver for iPhones
    $5.49
    Satın Al
    • Remove the 2.2 mm standoff screw from the grounding bracket.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  44. iPhone 7 Rear Case Replacement: adım 44, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 44, 2 resimden 2.
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
  45. iPhone 7 Rear Case Replacement, Lightning Connector Assembly: adım 45, 2 resimden 1. iPhone 7 Rear Case Replacement, Lightning Connector Assembly: adım 45, 2 resimden 2.
    • Use the point of a spudger to disconnect the lower cable connector.
  46. iPhone 7 Rear Case Replacement: adım 46, 1 resimden 1.
    • Remove the following screws:
    • One 1.4 mm Phillips screw
    • Three 2.2 mm standoff screws
    • Standoff screws are best removed using an [bağlı ürün eksik veya kapalı: IF145-343] and driver handle.
  47. iPhone 7 Rear Case Replacement: adım 47, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 47, 2 resimden 2.
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
  48. iPhone 7 Rear Case Replacement: adım 48, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 48, 2 resimden 2.
    • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
    • Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
  49. iPhone 7 Rear Case Replacement: adım 49, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 49, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 49, 3 resimden 3.
    • Lift the battery connector end of the logic board and pull it up and out of the rear case.
    • Be careful not to snag the logic board on any cables.
  50. iPhone 7 Rear Case Replacement: adım 50, 1 resimden 1.
    • Remove the 2.9 mm Phillips screw from the lightning connector.
  51. iPhone 7 Rear Case Replacement: adım 51, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 51, 2 resimden 2.
    • Remove the spring contact from the lightning connector.
  52. iPhone 7 Rear Case Replacement: adım 52, 1 resimden 1.
    • Remove the two 1.6 mm Phillips screws securing the lightning connector cable in place.
  53. iPhone 7 Rear Case Replacement: adım 53, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 53, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 53, 3 resimden 3.
    • Remove the two stickers covering the screws that secure the lightning connector to the bottom of the rear case.
  54. iPhone 7 Rear Case Replacement: adım 54, 1 resimden 1.
    • Remove the two 1.3 mm Phillips screws from the rear case.
  55. iPhone 7 Rear Case Replacement: adım 55, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 55, 2 resimden 2.
    • Use the pointed end of a spudger to separate the two microphones from the bottom of the rear case.
  56. iPhone 7 Rear Case Replacement: adım 56, 1 resimden 1.
    • Heating the lower edge of the iPhone will help soften the adhesive securing Lightning connector cable, making it easier to remove.
    • Use a hairdryer or reheat your iOpener to heat the lower edge of the phone.
    • Wait for about a minute, allowing the adhesive to warm up before proceeding to the next step.
  57. iPhone 7 Rear Case Replacement: adım 57, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 57, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 57, 3 resimden 3.
    • Starting from the middle of the phone, slide an opening pick underneath the lightning connector to separate it from the rear case.
  58. iPhone 7 Rear Case Replacement: adım 58, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 58, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 58, 3 resimden 3.
    • Continue to slide the pick towards the lightning connector to further separate the assembly from the rear case.
  59. iPhone 7 Rear Case Replacement: adım 59, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 59, 2 resimden 2.
    • Continue to slide the pick underneath the lightning connecter assembly.
    • Stop sliding the pick once it passes the battery.
  60. iPhone 7 Rear Case Replacement: adım 60, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 60, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 60, 3 resimden 3.
    • Starting at the corner of the phone, slide the pick underneath the assembly towards the lightning connector.
    • Stop sliding the pick when it reaches the lightning connector.
  61. iPhone 7 Rear Case Replacement: adım 61, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 61, 2 resimden 2.
    • Gently pull the lightning connector out of its hole on the rear case.
  62. iPhone 7 Rear Case Replacement: adım 62, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 62, 2 resimden 2.
    • Slide a pick below the lightning connector to further separate the lightning connector assembly from the rear case.
    • Continue to slide the pick until the lightning connector assembly is no longer adhered to the rear case.
  63. iPhone 7 Rear Case Replacement: adım 63, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 63, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 63, 3 resimden 3.
    • Remove the lightning connector assembly.
    • Before installing or replacing the Lightning connector assembly:
    • Use a plastic tool to scour any bits of adhesive residue from the rear case.
    • Make sure the Lightning connector assembly is correctly positioned so that the two white dots on the iPhone's rear case show through the two circular cutouts in the Lightning flex cable. If they don't, the flex cable will remain misaligned and you won't be able to reconnect it to its socket on the logic board.
  64. iPhone 7 Rear Case Replacement: adım 64, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 64, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 64, 3 resimden 3.
    • A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part.
    • The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
  65. iPhone 7 Rear Case Replacement, Rear Case Battery: adım 65, 2 resimden 1. iPhone 7 Rear Case Replacement, Rear Case Battery: adım 65, 2 resimden 2.
    • Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery.
  66. iPhone 7 Rear Case Replacement: adım 66, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 66, 2 resimden 2.
    • Use a pair of tweezers with blunt tips to peel back the other adhesive strip on the lower edge of the battery.
  67. iPhone 7 Rear Case Replacement: adım 67, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 67, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 67, 3 resimden 3.
    • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
    • Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
    • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
    • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
  68. iPhone 7 Rear Case Replacement: adım 68, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 68, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 68, 3 resimden 3.
    • Repeat the previous step for the second strip.
    • Hold down the battery as you remove the second strip, or the strip may fling the battery when it separates from the case.
    • If you removed both adhesive strips successfully, skip the next step.
    • Otherwise, if either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
  69. iPhone 7 Rear Case Replacement: adım 69, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 69, 2 resimden 2.
    Plastic Cards
    $2.99
    Satın Al
    • If you successfully removed both adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
    • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
    • After about a minute, remove the iOpener, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
    • Avoid bending the battery. Damage to the battery may release dangerous chemicals, and could start a fire.
    • Do not pry under the top third of the battery, you may damage the volume button ribbon cable.
  70. iPhone 7 Rear Case Replacement: adım 70, 1 resimden 1.
    • Remove the battery from the rear case.
    • When installing the battery, refer to this guide to replace your battery's adhesive strips.
  71. iPhone 7 Rear Case Replacement, Power and Volume Control Cable: adım 71, 2 resimden 1. iPhone 7 Rear Case Replacement, Power and Volume Control Cable: adım 71, 2 resimden 2.
    • Two 1.9 mm screws securing the power button.
    • Three 2.3 mm screws securing the volume buttons.
  72. iPhone 7 Rear Case Replacement: adım 72, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 72, 2 resimden 2.
    • Remove the following 1.3 mm Phillips screws:
    • One screw beside the rear-facing camera
    • One screw on the rear case
  73. iPhone 7 Rear Case Replacement: adım 73, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 73, 2 resimden 2.
    • From the outside of the phone, push the hold switch into the rear case with the point of a spudger.
    • This action will free the hold switch and gasket from the rear case.
  74. iPhone 7 Rear Case Replacement: adım 74, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 74, 2 resimden 2.
    • Use a pair of tweezers to remove the rear-facing camera.
  75. iPhone 7 Rear Case Replacement: adım 75, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 75, 2 resimden 2.
    • Moving from power button side of the phone, use an opening pick to separate the adhesive holding the antenna flex cable to the rear case.
  76. iPhone 7 Rear Case Replacement: adım 76, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 76, 2 resimden 2.
    • Slide the point of an opening pick underneath the antenna flex cable towards the top of the phone, separating the remaining adhesive.
  77. iPhone 7 Rear Case Replacement: adım 77, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 77, 2 resimden 2.
    • Use tweezers to move the antenna flex cable away from the edge of the phone, freeing the screw bracket from the rear case.
    • Remove the antenna flex cable.
  78. iPhone 7 Rear Case Replacement: adım 78, 1 resimden 1.
    • Remove the 2.3 mm standoff screw securing the flash bracket to the rear case.
  79. iPhone 7 Rear Case Replacement: adım 79, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 79, 2 resimden 2.
    • Remove the flash bracket.
  80. iPhone 7 Rear Case Replacement: adım 80, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 80, 2 resimden 2.
    • Use the point of a spudger to gently unseat the flash module.
  81. iPhone 7 Rear Case Replacement: adım 81, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 81, 2 resimden 2.
    • Use the blade of a Halberd spudger to separate the adhesive holding the microphone to the rear case.
  82. iPhone 7 Rear Case Replacement: adım 82, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 82, 2 resimden 2.
    • Gently fold the power button module from the edge of the rear case.
  83. iPhone 7 Rear Case Replacement: adım 83, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 83, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 83, 3 resimden 3.
    • Slide the blade of a halberd spudger under the power button end of the button cable to separate it from the adhesive on the rear case.
    • Continue to separate the adhesive by moving the blade towards the top of the phone.
  84. iPhone 7 Rear Case Replacement: adım 84, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 84, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 84, 3 resimden 3.
    • Continue to move the blade of the halberd spudger underneath the power and volume control cable.
    • Move slowly to make sure that the cable is not damaged during removal.
  85. iPhone 7 Rear Case Replacement: adım 85, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 85, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 85, 3 resimden 3.
    • Slide the halberd spudger under the volume control portion of the button cable.
    • Gently slide the blade underneath the cable towards the bottom of the phone, separating the remaining adhesive.
  86. iPhone 7 Rear Case Replacement: adım 86, 1 resimden 1.
    • Remove the power and volume control cable.
  87. iPhone 7 Rear Case Replacement, Power Button: adım 87, 2 resimden 1. iPhone 7 Rear Case Replacement, Power Button: adım 87, 2 resimden 2.
    • Pull the clip towards the bottom of the phone and lift up to free it from the bracket.
  88. iPhone 7 Rear Case Replacement: adım 88, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 88, 2 resimden 2.
    • Remove the clip from the rear case.
  89. iPhone 7 Rear Case Replacement: adım 89, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 89, 2 resimden 2.
    • Push the lower end of the power button bracket up off of peg securing it.
  90. iPhone 7 Rear Case Replacement: adım 90, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 90, 2 resimden 2.
    • Pull the bracket from the rear case.
  91. iPhone 7 Rear Case Replacement: adım 91, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 91, 2 resimden 2.
    • Use the pointed end of a spudger to push the power button cover out of the rear case.
    • Remove the power button cover.
  92. iPhone 7 Rear Case Replacement, Volume Buttons: adım 92, 2 resimden 1. iPhone 7 Rear Case Replacement, Volume Buttons: adım 92, 2 resimden 2.
    • Pull the volume button clip towards the bottom of the phone to free it from the bracket.
  93. iPhone 7 Rear Case Replacement: adım 93, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 93, 2 resimden 2.
    • Pull the clip towards the top of the phone to remove it.
  94. iPhone 7 Rear Case Replacement: adım 94, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 94, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 94, 3 resimden 3.
  95. iPhone 7 Rear Case Replacement: adım 95, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 95, 2 resimden 2.
    • Slide the flat end of a spudger underneath the bottom edge of the volume button bracket.
    • Adjust the spudger so that it can move away from the rear case without contacting the protruding peg that is on the volume button.
    • Rotate the spudger to pop the bracket off of the peg on the volume button.
  96. iPhone 7 Rear Case Replacement: adım 96, 2 resimden 1. iPhone 7 Rear Case Replacement: adım 96, 2 resimden 2.
  97. iPhone 7 Rear Case Replacement: adım 97, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 97, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 97, 3 resimden 3.
    • Repeat the procedure to remove the second volume button bracket.
  98. iPhone 7 Rear Case Replacement: adım 98, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 98, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 98, 3 resimden 3.
    • Use the pointed end of a spudger to push each of the volume button covers out of the rear case.
    • Remove the volume button covers.
  99. iPhone 7 Rear Case Replacement, Rear Case: adım 99, 3 resimden 1. iPhone 7 Rear Case Replacement, Rear Case: adım 99, 3 resimden 2. iPhone 7 Rear Case Replacement, Rear Case: adım 99, 3 resimden 3.
    • Use the point of a spudger to push the left rubber speaker vent out of the rear case.
  100. iPhone 7 Rear Case Replacement: adım 100, 3 resimden 1. iPhone 7 Rear Case Replacement: adım 100, 3 resimden 2. iPhone 7 Rear Case Replacement: adım 100, 3 resimden 3.
    • Repeat the procedure to push the right rubber speaker vent out of the rear case.
  101. iPhone 7 Rear Case Replacement: adım 101, 1 resimden 1.
    • Remove the 1.5 mm Phillips screw securing the grounding bracket.
  102. iPhone 7 Rear Case Replacement: adım 102, 1 resimden 1.
    • Remove the grounding bracket.
  103. iPhone 7 Rear Case Replacement: adım 103, 1 resimden 1.
    • Only the rear case remains.
Sonuç
71 farklı kişi bu kılavuzu tamamladı.
Scott Havard
49.630 İtibar
31 adet Kılavuz yazıldı
10 Yorum
Great manual. I was successful in this repair but bought a rear case with small parts. Safes up a lot of work and time :)
Dreetn - Yanıt
Great Guide!
There are some components that may need to be transferred to your new case, which are not in this guide:
1 speaker screens
2 screen mounting catches
3 put the SIM card tray ejector pin back in BEFORE the logic board. I inserted it before mounting the logic board, otherwise the pin may fall out.
Mike - Yanıt
Hello everyone!
Has anyone had problems with reception, especially the 4G network, after replacing the body with a non-original one?
thank you and sorry for my terrible english!
Giovanni Fasoli - Yanıt
Merci tres bon tutoriel tout c’est bien passé
jean.dujardin - Yanıt
HIW much cost to changing it
ishfaqbhat11 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 65
Son 30 gün: 276
Her zaman: 170,347
