Ana içeriğe geç
iPhone 8 Back Glass Replacement
Videoya Genel Bakış
  1. iPhone 8 Back Glass Replacement, iPhone 8 Back Glass Replacement: adım 1, 1 resimden 1.
    • Wire up the Back Glass Separator. Connect the Back Glass Separator with Air Compressor via an air pipe. Switch on the Air Compressor. Open the air compressor valve.
    • Switch on the Back Glass Separator. Rotate the pressure regulating valve and set the value as 0.4Mpa.
    FixBot'a Sor
    Yorum Ekle
  2. iPhone 8 Back Glass Replacement: adım 2, 2 resimden 1. iPhone 8 Back Glass Replacement: adım 2, 2 resimden 2.
    • Place iPhone 8 back glass assembly into the corresponding mold. Press ‘Up’. With the temperature rising to 240℃, press ‘Start’. The back glass assembly is clamped tightly by the mold.
    • After 200 seconds of heating, mandril of the machine starts to work.
    FixBot'a Sor
    Yorum Ekle
  3. iPhone 8 Back Glass Replacement: adım 3, 1 resimden 1.
    • Remove the back glass after 18 seconds. Remove glue residue on the back glass thoroughly.
    • iPhone 8 back glass separating has been completed successfully.
    • Attach a new back glass to the midframe in the end.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
15 farklı kişi bu kılavuzu tamamladı.
Phryne
21.835 İtibar
18 adet Kılavuz yazıldı
1Rehber Yorum
Where does it show the replacement I only see the removal?
ManDeen - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 59
Son 30 gün: 293
Her zaman: 60,665
