Ana içeriğe geç
iPhone 8 Back Glass Replacement
Videoya Genel Bakış
  1. iPhone 8 Back Glass Replacement, iPhone 8 Back Glass Replacement: adım 1, 1 resimden 1.
    • Wire up the Back Glass Separator. Connect the Back Glass Separator with Air Compressor via an air pipe. Switch on the Air Compressor. Open the air compressor valve.
    • Switch on the Back Glass Separator. Rotate the pressure regulating valve and set the value as 0.4Mpa.
    unless you are planning to replace multiple Back Glasses, purchasing a tool like this is not an interesting solution. The entire housing can be picked up for about 30$ with usb elements present ... although you will have a 4 to 5 hour job putting everything back together.
    Bill McNamara - Yanıt
  2. iPhone 8 Back Glass Replacement: adım 2, 2 resimden 1. iPhone 8 Back Glass Replacement: adım 2, 2 resimden 2.
    • Place iPhone 8 back glass assembly into the corresponding mold. Press ‘Up’. With the temperature rising to 240℃, press ‘Start’. The back glass assembly is clamped tightly by the mold.
    • After 200 seconds of heating, mandril of the machine starts to work.
  3. iPhone 8 Back Glass Replacement: adım 3, 1 resimden 1.
    • Remove the back glass after 18 seconds. Remove glue residue on the back glass thoroughly.
    • iPhone 8 back glass separating has been completed successfully.
    • Attach a new back glass to the midframe in the end.
Bitiş Çizgisi
13 farklı kişi bu kılavuzu tamamladı.
Phryne
21.023 İtibar
18 adet Kılavuz yazıldı
1Rehber Yorum
Where does it show the replacement I only see the removal?
ManDeen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 85
Son 30 gün: 500
Her zaman: 56,006
