Ana içeriğe geç
iPhone 8 Disassembly
Neye ihtiyacın var
    1. iPhone 8 Disassembly, Power Off: adım 1, 1 resimden 1.
      • First turn off the device to avoid any damage during disassembly.
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 8 Disassembly, Unscrew: adım 2, 1 resimden 1.
      • Remove the two screws to the left and right of the charging/headphone jack with a suitable screwdriver
      FixBot'a Sor
      Yorum Ekle
    3. iPhone 8 Disassembly, Loosen the display: adım 3, 2 resimden 1. iPhone 8 Disassembly, Loosen the display: adım 3, 2 resimden 2.
      • Work your way around the iphone with a pick (or fingernail). Start in one corner, to loosen the adhesive and retaining tabs. After that, the display should lay loosely with a gap of about 2mm on the phone.
      • Warning: pry carefully at the top of the screen. Here the display is not yet freed from the case!
      FixBot'a Sor
      Yorum Ekle
    4. iPhone 8 Disassembly, Open the cell phone: adım 4, 1 resimden 1.
      • Now you can open the display to the left. Attention: no further than 90⁰, otherwise the ribbon cables of the display will break off.
      FixBot'a Sor
      Yorum Ekle
    5. iPhone 8 Disassembly, Detach the display cable: adım 5, 2 resimden 1. iPhone 8 Disassembly, Detach the display cable: adım 5, 2 resimden 2.
      • Under this sheet metal are all the important cables of the phone. This sheet is fastened with four small Phillips screws. After removing the sheet, carefully lift the two display cable connectors with your fingernail until they unplug from the board.
      FixBot'a Sor
      Yorum Ekle
    6. iPhone 8 Disassembly, Detach the second display cable: adım 6, 1 resimden 1.
      • Under this sheet are the cable for the speaker/front camera and the cable for the main camera. First, loosen the cable for the front camera to remove the display completely.
      FixBot'a Sor
      Yorum Ekle
    7. iPhone 8 Disassembly, Remove Camera and Bluetooth Antenna: adım 7, 2 resimden 1. iPhone 8 Disassembly, Remove Camera and Bluetooth Antenna: adım 7, 2 resimden 2.
      • The camera sits under this sheet metal. The sheet metal is held in place by two screws. After removing the sheet metal, unplug the camera cable and remove the camera.
      • The Bluetooth antenna is curved into the corner of the phone. It is secured to the housing with a screw and to the circuit board with another screw
      FixBot'a Sor
      Yorum Ekle
    8. iPhone 8 Disassembly, Removing the rear microphone: adım 8, 1 resimden 1.
      • The microphone is attached to the housing with a screw and to the back panel with a screw. Both screws must be removed and when doing so note that the microphone is also glued.
      FixBot'a Sor
      Yorum Ekle
    9. iPhone 8 Disassembly, Remove NFC Cover: adım 9, 1 resimden 1.
      • Now remove the cover of the NFC device. After removing the cover, the board is only held in place by three screws.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Juan Garcia dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Jan Phönix
385 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 42
Son 30 gün: 201
Her zaman: 1,771
