Ana içeriğe geç
iPhone 8 Speaker Replacement
Neye ihtiyacın var
  1. iPhone 8 Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Sim card tray removal. This step is necessary as seen in Step 7.
    • Let the battery drain below 25% and power off the device before starting the repair.
  2. iPhone 8 Speaker Replacement: adım 2, 2 resimden 1. iPhone 8 Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the two bottom screws using the P2 bit in the Pro Tech Tool Kit.
  3. iPhone 8 Speaker Replacement: adım 3, 3 resimden 1. iPhone 8 Speaker Replacement: adım 3, 3 resimden 2. iPhone 8 Speaker Replacement: adım 3, 3 resimden 3.
    • Insert the Jimmy into the right side of the phone. Putting the Jimmy in the middle could crack the glass and/or break the home button. Also, don't put the Jimmy into the left side because you could break the home button cable. Use a small box to prop up the display as shown in picture 3.
  4. iPhone 8 Speaker Replacement: adım 4, 3 resimden 1. iPhone 8 Speaker Replacement: adım 4, 3 resimden 2. iPhone 8 Speaker Replacement: adım 4, 3 resimden 3.
    • Before we disconnect the display, we need to unplug the battery connector. If you don't unplug the battery first, you could damage the back light on the screen.
  5. iPhone 8 Speaker Replacement: adım 5, 2 resimden 1. iPhone 8 Speaker Replacement: adım 5, 2 resimden 2.
    • Now to remove the display. There are 3 more screws that we need to remove, then we can disconnect the 3 cables.
    • Remove the display from the housing.
  6. iPhone 8 Speaker Replacement: adım 6, 1 resimden 1.
    • Now we need to remove this bracket. The screw next to the Taptic Engine is a Y000.
  7. iPhone 8 Speaker Replacement: adım 7, 2 resimden 1. iPhone 8 Speaker Replacement: adım 7, 2 resimden 2.
    • Disconnect the marked flex cables, then push the sim pin ejector into the frame. Now remove the 3 screws holding the speaker in place. Lift the speaker up and remove it as shown in picture 2.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cell Phone Helper
433 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 23
Son 7 gün: 175
Son 30 gün: 390
Her zaman: 978
