Giriş
Follow this guide to replace the Wi-Fi diversity antenna and flex cable for your iPhone 8. This may help resolve connectivity issues.
Opening the iPhone 8 will damage the waterproof seals on the display. If you do not replace the adhesive seals, your phone will function normally, but will no longer be water-resistant.
Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
  • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
  • Power off your iPhone before beginning disassembly.
  • Opening the iPhone's display will damage its waterproof seals. If you do not replace the seals, your phone will no longer be water resistant.
  • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
Yorum Ekle
Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
  • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
  • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
Yorum Ekle
Apply a suction cup to the lower half of the front panel, just above the home button. Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
Yorum Ekle
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Insert an opening pick into the gap. The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
  • Insert an opening pick into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
The screen on my phone was so broken, a suction cup did not work, so I softened the adhesive with a blow dryer and used a Jimmy to carefully pry open the phone from the bottom just enough to slip a pick in.
charguy - Yanıt
Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place. Stop near the top left corner of the display. Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
  • Stop near the top left corner of the display.
  • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
Yorum Ekle
Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive. Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel. Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel.
  • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel.
Yorum Ekle
Gently pull up on the suction cup to lift up the bottom edge of the display. Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
  • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
  • Pull on the small nub on the suction cup to remove it from the front panel.
Yorum Ekle
Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive. Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive. Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
  • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
Yorum Ekle
Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case. Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
Yorum Ekle
Open the iPhone by swinging the display up from the left side, like the back cover of a book. Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board. Lean the display against something to keep it propped up while you're working on the phone.
  • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  • Lean the display against something to keep it propped up while you're working on the phone.
Yorum Ekle
  • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • Two 2.8 mm screws
  • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  • Remove the bracket.
Not Y000 this time haha
Easy Repair - Yanıt
Use the point of a spudger to pry the battery connector out of its socket in the logic board. Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  • Use the point of a spudger to pry the battery connector out of its socket in the logic board.
  • Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Yorum Ekle
Use the point of a spudger to pry the lower display connector out of its socket. To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  • Use the point of a spudger to pry the lower display connector out of its socket.
  • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
Yorum Ekle
Use the point of a spudger to disconnect the second lower display cable. Use the point of a spudger to disconnect the second lower display cable.
  • Use the point of a spudger to disconnect the second lower display cable.
Yorum Ekle
Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector. Remove the bracket.
  • Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
Yorum Ekle
Use the point of a spudger to disconnect the  front panel sensor assembly connector. Use the point of a spudger to disconnect the  front panel sensor assembly connector.
  • Use the point of a spudger to disconnect the front panel sensor assembly connector.
Yorum Ekle
Remove the display assembly.
Yorum Ekle
Remove the three screws securing the bracket next to the Taptic Engine:
  • Remove the three screws securing the bracket next to the Taptic Engine:
  • One 1.3 mm Y000 screw
  • One 2.7 mm Phillips screw
  • One 2.9 mm Phillips screw
Yorum Ekle
Remove the bracket.
Yorum Ekle
Gently slide an opening pick between the antenna flex cable and the top of the speaker. This portion of the flex cable is lightly adhered in place. If necessary, apply a little heat from an iOpener or hair dryer to soften the adhesive. This will make it easier to separate the flex cable safely. This portion of the flex cable is lightly adhered in place. If necessary, apply a little heat from an iOpener or hair dryer to soften the adhesive. This will make it easier to separate the flex cable safely.
  • Gently slide an opening pick between the antenna flex cable and the top of the speaker.
    • This portion of the flex cable is lightly adhered in place. If necessary, apply a little heat from an iOpener or hair dryer to soften the adhesive. This will make it easier to separate the flex cable safely.
Yorum Ekle
Use the point of a spudger to pry up and disconnect the diversity antenna flex cable from the logic board. Use the point of a spudger to pry up and disconnect the diversity antenna flex cable from the logic board.
  • Use the point of a spudger to pry up and disconnect the diversity antenna flex cable from the logic board.
Yorum Ekle
Slide an opening pick under the antenna flex cable to hold the socket down. Use the point of your spudger to pry up and disconnect the antenna flex cable from its socket, using the opening pick to hold the socket down. Reconnecting this cable can be tricky. Make it easier by using your tweezers to hold the flex cable so the connector aligns with its socket. Then, gently press straight down on the connector with the flat of your spudger until it clicks into place.
  • Slide an opening pick under the antenna flex cable to hold the socket down.
  • Use the point of your spudger to pry up and disconnect the antenna flex cable from its socket, using the opening pick to hold the socket down.
    • Reconnecting this cable can be tricky. Make it easier by using your tweezers to hold the flex cable so the connector aligns with its socket. Then, gently press straight down on the connector with the flat of your spudger until it clicks into place.
Yorum Ekle
Remove the Wi-Fi diversity antenna.
  • Remove the Wi-Fi diversity antenna.
Yorum Ekle
Sonuç
To reassemble your device, reapply the display adhesive and follow these instructions in reverse order.
Repair didn’t go as planned? Check out our iPhone 8 Answers community for troubleshooting help.
Bir başkası bu kılavuzu tamamladı.
Arthur Shi
14.178 İtibar
100 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
113 Üyeler
6.002 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 Gün: 111
Son 30 Gün: 206
Her zaman: 206
