Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The Taptic Engine produces your iPhone's vibration and haptic feedback functions. Use this guide to remove and/or replace the Taptic Engine in an iPhone SE 2020.
Note: This guide instructs you to fully detach and remove the display assembly; this is intended to make the phone easier to work with and to prevent accidental damage to the display cables. If you feel comfortable removing the Taptic Engine while keeping the display cables attached, you can skip the steps for disconnecting the display.
Neye ihtiyacın var
Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
Bu adımda kullanılan alet:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap.
Skip the next three steps.
Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
Apply a suction cup to the lower half of the front panel, just above the home button.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
Two 1.3 mm screws
Two 2.8 mm screws
Remove the bracket.
Use the point of a spudger to pry the lower display connector out of its socket.
Remove the three screws securing the bracket next to the Taptic Engine:
One 1.3 mm Y000 screw
One 2.7 mm Phillips screw
One 2.9 mm Phillips screw
Bu adımda kullanılan alet:Standoff Screwdriver for iPhones$5.49
Remove the two screws securing the Taptic Engine:
One 2.1 mm Phillips screw
One 2.1 mm standoff screw
To reassemble your device, follow these instructions in reverse order. Don't forget to reapply the display adhesive before reinstalling the display.
Repair didn’t go as planned? Check out our iPhone SE 2020 Answers community for troubleshooting help.
7 farklı kişi bu kılavuzu tamamladı.
