Ana içeriğe geç
iPhone X Disassembly
Neye ihtiyacın var
Videoya Genel Bakış
    1. iPhone X Disassembly, Turn off the phone and remove SIM Card: adım 1, 2 resimden 1. iPhone X Disassembly, Turn off the phone and remove SIM Card: adım 1, 2 resimden 2.
      • Press the wake button and volume down button to turn off the phone.
      FixBot'a Sor
      Yorum Ekle
    2. iPhone X Disassembly, Open the phone: adım 2, 3 resimden 1. iPhone X Disassembly, Open the phone: adım 2, 3 resimden 2. iPhone X Disassembly, Open the phone: adım 2, 3 resimden 3.
      • Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will allow the phone to be opened more easily.
      FixBot'a Sor
      Yorum Ekle
    3. iPhone X Disassembly, Remove the iPhone X OLED screen: adım 3, 3 resimden 1. iPhone X Disassembly, Remove the iPhone X OLED screen: adım 3, 3 resimden 2. iPhone X Disassembly, Remove the iPhone X OLED screen: adım 3, 3 resimden 3.
      • Undo 5 screws shown in the picture below with a tripoint #Y000 screwdriver
      • These screws are all different sized so keep track of where they go
      • Release the battery/LCD screen/digitizer/ear speaker connectors with a spudger.
      FixBot'a Sor
      Yorum Ekle
    4. iPhone X Disassembly, Remove the ear speaker: adım 4, 2 resimden 1. iPhone X Disassembly, Remove the ear speaker: adım 4, 2 resimden 2.
      • Undo 3 Y000 screws and heating the flex cable with a heat gun, we can remove the ear speaker easily
      FixBot'a Sor
      Yorum Ekle
    5. iPhone X Disassembly, Remove rear-facing cameras.: adım 5, 1 resimden 1.
      • Remove the 2 Phillips #PH00 screws and remove the metal plate, release the rear cameras connectors.
      • These screws are also different sizes
      FixBot'a Sor
      Yorum Ekle
    6. iPhone X Disassembly, Remove motherboard.: adım 6, 2 resimden 1. iPhone X Disassembly, Remove motherboard.: adım 6, 2 resimden 2.
      • Release all connectors on the motherboard with a spudger
      • Undo 3 Phillips #PH00 screws on the mother board then we can take out the mother board.
      FixBot'a Sor
      Yorum Ekle
    7. iPhone X Disassembly, Remove Loudspeaker and Taptic engine: adım 7, 3 resimden 1. iPhone X Disassembly, Remove Loudspeaker and Taptic engine: adım 7, 3 resimden 2. iPhone X Disassembly, Remove Loudspeaker and Taptic engine: adım 7, 3 resimden 3.
      • Undo 8 screws on the retaining plate then remove the plate taking care to not break the small connector on the plate that connects just under the taptic engine
      • Remove the loud speaker and the taptic engine.
      FixBot'a Sor
      Yorum Ekle
    8. iPhone X Disassembly, Remove battery: adım 8, 2 resimden 1. iPhone X Disassembly, Remove battery: adım 8, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Pulling out 4 battery adhesives with a tweezers then we can remove the battery.
      FixBot'a Sor
      Yorum Ekle
    9. iPhone X Disassembly, Remove front-facing camera: adım 9, 2 resimden 1. iPhone X Disassembly, Remove front-facing camera: adım 9, 2 resimden 2.
      • Heating the front facing camera with a heat gun will make it easily to be removed
      FixBot'a Sor
      Yorum Ekle
    10. iPhone X Disassembly, Remove the charging port and antenna: adım 10, 3 resimden 1. iPhone X Disassembly, Remove the charging port and antenna: adım 10, 3 resimden 2. iPhone X Disassembly, Remove the charging port and antenna: adım 10, 3 resimden 3.
      • Release 4 screws on the frame shown in the picture
      • Heating the charging port flex cable then we can remove it easily
      FixBot'a Sor
      Yorum Ekle
    11. iPhone X Disassembly, Remove Wi-Fi antenna: adım 11, 3 resimden 1. iPhone X Disassembly, Remove Wi-Fi antenna: adım 11, 3 resimden 2. iPhone X Disassembly, Remove Wi-Fi antenna: adım 11, 3 resimden 3.
      • Release 7 screws on the Wi-Fi flex cable
      • Heating the flex cable with a heat gun make it easier to be removed
      FixBot'a Sor
      Yorum Ekle
    12. iPhone X Disassembly, Remove power button flex cable: adım 12, 3 resimden 1. iPhone X Disassembly, Remove power button flex cable: adım 12, 3 resimden 2. iPhone X Disassembly, Remove power button flex cable: adım 12, 3 resimden 3.
      • Release 3 screws on the power button
      • Heating the flex cable with a heat gun then it can be removed easily
      FixBot'a Sor
      Yorum Ekle
Sonuç
134 farklı kişi bu kılavuzu tamamladı.
Mandy
9.612 İtibar
9 adet Kılavuz yazıldı
26Kılavuz Yorumları
It's good
Chalak Chomani - Yanıt Paylaş
excellent guide!!!
Andy Lee - Yanıt Paylaş
The iPhone X assemble video: https://youtu.be/E5jyuxgpE_g
Mandy - Yanıt Paylaş
What About the backside ? I heard that when the backside is shattered, it’s almost impossible to repair, because of the glue that holds the backside and parts together ?
Arnoud - Yanıt Paylaş
Hi avdk, we don’t tear down the back glass but we will pay attention to this question. If there is a definite answer, I will reply to you .Thank you.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 114
Son 30 gün: 527
Her zaman: 234,326
