Giriş
バッテリーが長持ちしませんか?交換しましょう。
Aletler
Parçalar
開口ピックを、iPod右端のプラスチックのフロントとメタルのリアパネルの間の継ぎ目(シーム)深くまで差し込みます。
開口ピックを使って、プラスチックのフロントパネル側をこじ開けて、5つの固定用タブを外します。(3番目の画像参照)
iPodの端に沿ってピックをスライドして、残りのタブを外していきます。
右側の5つの固定用タブが外れたら、ケースは簡単に開きます。
プラスチック製ツールや指の爪を使って、オレンジ色のヘッドホンジャックケーブルの接続を注意深く外します。ケーブルではなく、コネクタのみをまっすぐ引き上げているか確認してください。
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
318 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
16 Yorum
If you are real careful you don't have to remove the Torx screw to get the battery out.
I found this quite easy. The tools worked great. I agree with Andy, if you push the tool into the groove, then lift or pry it up so the tip of the tool is down inside the back cover, you should be able to slide it across to pop the clips quite easily. Once you get the first two sides open, it goes quick.
I also did this without having to remove the Torx screw. It helped to lift the battery up a bit to give the wires a little slack, and then just feed them around the corner of the motherboard. Putting the new battery in, I just fed the wires around the corner, and used the opening tool to push them the final bit of the way around the corner.
My old iPod is like new now! Hours and hours of battery life, when it would previously die after 5 minutes.
Very simple and clear guide. I managed to replace the battery in the first try and it worked!
I was able to do it without disconnecting the headphone jack and without removing the Torx screw.
I found the replacement battery to be a little thicker than the original battery but there was no issue resealing the case.
