Giriş
Replace a cracked or faulty display.
Neye ihtiyacın var
Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. It helps to hold the iPod at top and bottom as shown and squeeze to help pop out the edge. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
Lift the battery up from the adhesive holding it to the iPod.
Lay the battery next to the iPod (it is still connected to the logic board).
Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
How do you connect new display screen?
Boy, are these cases hard to open! I got nowhere with the spudger, but I did have success using duct tape. This is worth trying as it reduces the likelihood of scratching the case. Make a tab by sticking duct tape to the metal case starting on the side down by the scrolll wheel and ending up where the metal case ends on the firewire side. Fold excess duct tape back on itself so that it is 2x thick anywhere it isn’t stuck to the iPod. This is where you are going to grab it. Rub the duct tape with a spudger or a fingernail where it touches the iPod to make it stick better. Make a similar tab on the other side. Now grab the iPod in your right hand with your thumb at the 1/8” audio connector, squeeze gently, and pull on one of the duct tape tabs. (I stared with the one of the lock button side, but I don’t think it matters.) It is smooth sailing once the case starts to open up. Clean off any duct tape residue with alcohol wipes before re-assembly.
R Calhoun - Yanıt
Well, maybe for you because you have baby hands and, it Took me less Then a minute to do it
Matthew Cabanas -
