Ana içeriğe geç
iPod 1st Generation Hard Drive Cable Replacement
Neye ihtiyacın var
  1. iPod 1st Generation Hard Drive Cable Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    FixBot'a Sor
    Yorum Ekle
  2. iPod 1st Generation Hard Drive Cable Replacement: adım 2, 1 resimden 1.
    • Opening the iPod can be challenging; don't get discouraged if it takes you a few tries to get the iPod to open.
    • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. It helps to hold the iPod at top and bottom as shown and squeeze to help pop out the edge. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
    FixBot'a Sor
    Yorum Ekle
  3. iPod 1st Generation Hard Drive Cable Replacement: adım 3, 1 resimden 1.
    • Continue to run the opening tool along the side of the case until all five tabs have been released.
    FixBot'a Sor
    Yorum Ekle
  4. iPod 1st Generation Hard Drive Cable Replacement: adım 4, 1 resimden 1.
    • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
    FixBot'a Sor
    Yorum Ekle
  5. iPod 1st Generation Hard Drive Cable Replacement: adım 5, 1 resimden 1.
    • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
    • Lift the rear panel away from the iPod.
    FixBot'a Sor
    Yorum Ekle
  6. iPod 1st Generation Hard Drive Cable Replacement, Hard Drive: adım 6, 1 resimden 1.
    • Lift the battery up from the adhesive holding it to the iPod.
    • Lay the battery next to the iPod (it is still connected to the logic board).
    FixBot'a Sor
    Yorum Ekle
  7. iPod 1st Generation Hard Drive Cable Replacement: adım 7, 1 resimden 1.
    • Carefully disconnect the orange ribbon cable from the hard drive.
    • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
    • Lift the hard drive out of the iPod.
    FixBot'a Sor
    Yorum Ekle
  8. iPod 1st Generation Hard Drive Cable Replacement, Hard Drive Cable: adım 8, 1 resimden 1.
    • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
    FixBot'a Sor
    Yorum Ekle
  9. iPod 1st Generation Hard Drive Cable Replacement: adım 9, 1 resimden 1.
    • Peel up the gray rubber bumper near the hard drive ribbon to reveal the T6 Torx screw beneath.
    • Remove the newly revealed T6 Torx screw.
    FixBot'a Sor
    Yorum Ekle
  10. iPod 1st Generation Hard Drive Cable Replacement: adım 10, 1 resimden 1.
    • Remove the remaining 3 T6 Torx screws from the logic board.
    FixBot'a Sor
    Yorum Ekle
  11. iPod 1st Generation Hard Drive Cable Replacement: adım 11, 1 resimden 1.
    • Slide the logic board away from the port end of the casing and lift it out of the iPod.
    FixBot'a Sor
    Yorum Ekle
  12. iPod 1st Generation Hard Drive Cable Replacement: adım 12, 1 resimden 1.
    • Use a spudger to carefully disconnect the orange hard drive cable from beneath the scroll wheel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 42
Her zaman: 9,945
