Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Connects the hard drive to the logic board.
Neye ihtiyacın var
Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. It helps to hold the iPod at top and bottom as shown and squeeze to help pop out the edge. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
Lift the battery up from the adhesive holding it to the iPod.
Lay the battery next to the iPod (it is still connected to the logic board).
Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
4 farklı kişi bu kılavuzu tamamladı.
